It is currently Fri Jul 25, 2025 9:03 am
 Post subject: Painting a Mini
PostPosted: Sun Oct 21, 2007 1:10 pm
Die Die Die!!
for those you payed to have their mini painted..
what was the average price you payed for sandblasting the shell
and painting inside and out ? if you could tell me what colours (ei. 1 or 2) you got as well that would be helpfull
PostPosted: Sun Oct 21, 2007 4:05 pm
To get your mini blastered looking around $600-$800
Then there is the rust repairs, and no your mini will not be rust free i dont care what year it is. This could be as cheap as 2-3 days work $1000, anywhere up to 2-3 weeks work $3000-$4000
Then paint will be minimum $2500 for paint/primer to be supplied and done in a booth.
1974 Moke - 998cc
PostPosted: Sun Oct 21, 2007 4:07 pm
Die Die Die!!
yeah i was going to ask about rust.. but its a bit of a hard question to ask.. due to varying levels of rust.. so i left it out but thats for that :)
yeah im looking to get mine blasted, deadened, and painted inside and out... in black.. im hoping $8000-9000 will be enough for a good paintjob...
PostPosted: Sun Oct 21, 2007 6:30 pm
That's a big budget.
Are you after a show finish?
I painted my car for much under a grand. But then again, I did all the body prep work, and my dad and I painted it together. Which means you need a compressor, paint gun...yadda yadda yadda.
As I recall Cookie720 (I think that's his ausmini name) got his done (iIn Adelaide) for under 2 grand, and looks really good.
PostPosted: Sun Oct 21, 2007 6:41 pm
$4000 - $6000 would usually be around the mark for a bare metal respray, but you can pay whatever you want really...
Noli Illegitimi Carborundum
PostPosted: Sun Oct 21, 2007 7:35 pm
Die Die Die!!
well yes i was looking to get close to a show class finish.. which is why i was budgeting for that ammount and would expect close to it
and that $8000-9000 was for paint, blasting and rust work.. not just the paint job...
PostPosted: Sun Oct 21, 2007 7:49 pm
Fair enough. And yes I understand that was for the lot. You could go cheaper if you did the prep work but I also understand that you may not have the time, or place to do it.
I jsut wonder if spending the value of the car on top of it, for paint was worth it? As long as you feel that it's worth it, that's all that matters. :)
PostPosted: Sun Oct 21, 2007 9:55 pm
Yep we did all the rust repairs, cutting out front floor bits and boot bits, replacing apanels all at home, so cost nothing, paint prep all ourselves, and paint cost like 200 for 4L acrylic and actual painting cost $850, which included last minute prep, (sanding if nessesary) and a last buff finish a couple months later
it is far from show though
PostPosted: Sun Oct 21, 2007 10:49 pm
I got my mini sand blasted for $400 by a guy down is gawler
PostPosted: Sun Oct 21, 2007 11:05 pm
any good recommendations for a good blaster and/or painter in Sydney??
also wat types of blasting are there and whats the difference between. i was told by domeone that there's a "sodabBlasting" which is VERY fine and something to do with walnut shells (i wasn't really paying attention :oops: )
PostPosted: Mon Oct 22, 2007 6:49 pm
i got quoted 250-300$ to get the mini sand blasted inside an out an under an in the boot an the engine bay. everything..
'94 Honda EG4 Civic. -Daily-
'95 Honda DC2 Integra
PostPosted: Mon Oct 22, 2007 6:51 pm
sode blasting leaves a fine coat of sumthing on the surface an needs to be sanded off ... and its not too good with the rust an bog ive heard.
PostPosted: Mon Oct 22, 2007 7:02 pm
sounds like your going allout nick, good on you. i would think, that you could add 1k or so to the normal price of a good paint job to do it in black, as it shows every single imperfection. what did harna's job cost? 8k? id allow that.
good on ya
PostPosted: Mon Oct 22, 2007 11:52 pm
Die Die Die!!
nice to see that im basically spot on with my guestimate :)
PostPosted: Tue Oct 23, 2007 1:17 am
pm me when you want it done, i know someone who is interested in doing it. :D
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
