It is currently Sun Jul 20, 2025 8:28 am
PostPosted: Tue Oct 23, 2007 11:54 am
Whats the difference between an original roundnose, and a newer model Rover ?
I know the grill is different, but what else ?
Is there a difference between a standard bonnet & a Rover bonnet ?
Is there anything else that was changed ?
Can an oldskool grill be fitted to a rover with minimum modifications ?
Can the pop-out style rear windows be fitted with minimum mods ?
No more Minis!......For now.
PostPosted: Tue Oct 23, 2007 11:57 am
The rover bonnet has an extra lip out the front to take the top trim that fits into the grille , the hinges are in the same position as a clubman (different to a roundie) so you can't swap bonnets easily but you can cut off the lip .
No idea on the rest but someone else should know .
PostPosted: Tue Oct 23, 2007 12:32 pm
Rear window is bigger, as are rear side windows.
Doors internally hinged, amd opening is bigger.
Subframes were rubber mounted, not directly mounted to body.
Classic grille will fit.
They're the main body differences.
:D
PostPosted: Tue Oct 23, 2007 12:58 pm
Maxi
Have you collected your car yet? I have been talking to Steve about getting a fuel tank and would like to ask if you could bring it with you back to the coast
regards - miniDave
Dave K.
PostPosted: Tue Oct 23, 2007 1:04 pm
Nah, no car yet. Maybe sooooon.
But if he can put it in the boot before it goes onto a TNT truck, then your more than welcome to use my car as a way of getting it up here.
PostPosted: Tue Oct 23, 2007 6:45 pm
Die Die Die!!
the door shape is different to older round nose mini's and is also bigger..
better body deadning
air vent holes in the firewall
different tail lights
no 1/4 windows
window winder winds backwards
also has different locking and opening mechanisms
are we going into stuff mounted to the car as well ? if so..
retractable seat belts
reclinable seats
different engine (A+)
some have air conditioning
some have Dashes
reclinable seats
some have air bags
same with seat belt pretensioners
the list goes on for that stuff...
PostPosted: Tue Oct 23, 2007 6:56 pm
you can fit oppening rear windows out of any uk car post arround 1970 (mk3 on).
Users browsing this forum: Bruce Hayward and 71 guests
