All the covers for magic wand and remote boxes are the same size, except Cooper S- which have 1/8" bigger bushes and seals in them.
All rodchange ones are the same dimensions as common ones above, but they have a lug on them to hold the detent spring in (it's under the RH cover).
If yours is a rodchange, you need a rodchange cover. If it's not, any cover will fit (except Cooper S).
I've not counted the automatics as they have a different design cover.
