It is currently Thu Jul 24, 2025 3:07 am
 Post subject: SS Wiring Diagram
PostPosted: Sun Oct 21, 2007 9:53 pm
Hi all,
Wondering if anybody out there has a wiring diagram for a clubman SS as i am doing one up for my mum and the loom is a mess. :?
Thanks Dean
PostPosted: Sun Oct 21, 2007 9:56 pm
My manual only has a Clubman wiring diagram, no additions for an SS.
Dicko
PostPosted: Sun Oct 21, 2007 10:00 pm
Yep so does mine, lots more extras on an SS
PostPosted: Sun Oct 21, 2007 10:03 pm
So the SS would also have Driving Lights, and heated rear window(?) I suppose. Anything else different?
PostPosted: Sun Oct 21, 2007 10:06 pm
Thanks for the diagram, but i have that one.
Also own a GT and there is heaps of different wires on an SS to contend with, does not help when it has been bastardised either.
PostPosted: Sun Oct 21, 2007 10:10 pm
Yes has driving lights, heated rear screen and voltage regulator for normal lights i think.
I no what colour the rear screen wires are.
Have very thick blue, blue and yellow wires that go to the dash
Under the bonnet have another thicker wirer which is a red with wellow i think??
PostPosted: Mon Oct 22, 2007 10:36 pm
you might be able to work out a few things from this generic diagram - its very self explanitary
PostPosted: Tue Oct 23, 2007 10:16 am
From memory, all of the extras were light green wires :) Or maybe that was just at the switch panel.
Anyway, the heated screen wires should be obvious as they'll be the only extra ones in the rear. The extra horn was just another pair of the same colour (purple?). The driving lights went straight to the switch with no fuse or relay. I think the wires ran all the way back from each light rather than one jumping over from the other.
If you are using the Gregory's manual you won't find the reversing light in the diagram either. That is another light green wire.
66 Deluxe, 07 Cooper
PostPosted: Tue Oct 23, 2007 10:26 am
d1ck0 wrote:
I've always wondered about those missing items Nos. 13, 20 & 25 :?
PostPosted: Tue Oct 23, 2007 10:10 pm
I hadn't even noticed that.
Dicko
