clutch https://www.ausmini.com/forums/viewtopic.php?f=2&t=37078 |
Page 1 of 2 |
Author: | mad-mk1 [ Thu Oct 25, 2007 1:47 am ] |
Post subject: | clutch |
hey gang, well mad-mk1 is running, now i have to organise the clutch, i am hoping to do taht this weekend! now what need s doing, ima clutch noob, im pretty sure everythings there. sorry to be so unhelpful ![]() cheers jamie |
Author: | sports850 [ Thu Oct 25, 2007 7:36 am ] |
Author: | mad-mk1 [ Thu Oct 25, 2007 10:45 am ] |
its never been hooked up in the car, ujust hadthe whole subby put in, im just not sure where to go from here, motors done 200ks since rebuild... |
Author: | AEG163job [ Thu Oct 25, 2007 11:26 am ] |
i spy with my little eye.................. Return spring has gone AWOL ![]() Adjust according to the manual & see how you go |
Author: | Anto [ Thu Oct 25, 2007 12:11 pm ] |
I would certainly look at buying a new clutch arm, top and bottom clevis pins and a clutch return spring. Easy to fit. I had a bent clutch arm like that in my car when I got it, I replaced it with a new one and a new clutch shuttle and fixed all of my clutch problems. Until the clutch shuttle wore out somewhat quickly - I always use unworn original items now as the new ones seem to be a bit average. |
Author: | Mini Mad [ Thu Oct 25, 2007 3:23 pm ] |
Yea that adjustable slave rod spells trouble.. |
Author: | Anto [ Thu Oct 25, 2007 4:12 pm ] |
I have an adjustable clutch rod on my car, I could never figure out why my clutch slowly stopped working until I realised the clutch push rod was adjusting itself shorter and shorter.... |
Author: | mr_a_series [ Thu Oct 25, 2007 8:50 pm ] |
the mini clutch is self adjusting yeah? |
Author: | Morris 1100 [ Thu Oct 25, 2007 8:53 pm ] |
mr_a_series wrote: the mini clutch is self adjusting yeah? Yes, you adjust it yourself. ![]() |
Author: | mr_a_series [ Thu Oct 25, 2007 8:57 pm ] |
ok my clutch engages when my pedal is almost to the floor..................how do u adjust the clutch...... |
Author: | matt van'74 [ Thu Oct 25, 2007 9:01 pm ] |
Wind the clutch arm stop out, it is situated on the clutch cover. 7/16 bolt by the way and dont forget to lock it up afterwards. Dont over adjust it though. Go a flat or two at a time. Matt |
Author: | AEG163job [ Thu Oct 25, 2007 9:27 pm ] |
and make sure there's a bit of clearance btw the stop and the clutch arm, say at least 5-10 thou ![]() |
Author: | mad-mk1 [ Mon Oct 29, 2007 11:55 pm ] |
ok kids ima we bit lost. i bled it, probably not well enough, but i have a we bit of clutch, but not much at all...... what do i do to g about adjusting it? also ona nother note, it backfires every now and tehn through the carby, how can i fix this. i ahve turned the dizzy to teh radiator side, but now teh vacuum trupety thing hits the oil cooler hose, and cant go no further... any help much appriiciated. clutch teh most. i wnated it finished for a important thing on friday. cheers jamie |
Author: | mickmini [ Tue Oct 30, 2007 12:12 am ] |
http://www.minimania.com/web/SCatagory/CLUTCH/DisplayType/Technical%20Information/DisplayID/153/ArticleV.cfm read learn cheers michael |
Author: | mad-mk1 [ Tue Oct 30, 2007 12:39 am ] |
i only really got teh technical bits, on why things do what they do, not really how to fix it. |
