It is currently Sun Jul 27, 2025 3:38 pm
 Post subject: carby disc addon
PostPosted: Wed Oct 24, 2007 9:35 am
I'm rebuilding a carby and i've noticed a few so far that have the disc with a little welded disc on 1 half. Why is this done?
Michael.
PostPosted: Wed Oct 24, 2007 9:42 am
I can answer that one since I know the bit you mean , it's a valve that's supposed to let a little air in when the throttle's closed , most people soldered them closed like that one has been , you can either replace the brass butterfly (disk) or use it as is .
PostPosted: Wed Oct 24, 2007 9:56 am
oh ok yeah i get it. i thought it was some weighting trick or something.
thanks for that.
PostPosted: Wed Oct 24, 2007 1:09 pm
Yes it was fitted to later carburettors for pollution control purposes I believe. In my experience you get better results replacing it with a standard disc, otherwise it can be a PITA to tune.
PostPosted: Thu Oct 25, 2007 7:51 pm
i thought it was an anti run on device
Users browsing this forum: drmini in aust and 83 guests
