13secmini wrote:
ok thanks guys, so what makes a californian a californian then? is it the chassis number? Are they all Galvanized?
does the chassis AKFPD 19Y line up with a cali if there were none in 81?
The '77 californian says so on the compliance plate, none of the others do. They are just a dress up kit, (something you could argue most of the later "specials" were). They just stickered them as Californians and voila, it was a californian. Californians were first sold from '71 to about -73. Then '77 to the end.
What made them special differed from year to year. The first ones in about '71 were brightly coloured, had floral "orange bali" hoods and seats and the steering wheels were color coded to the body. Some (possibly all) had a 1275 but not disks.
When they resurrected the idea again in '77 they had sports steering wheels, californian bumpers, sunraysia wheels and denim look vinyl upholstery, all were 998s. The same spec more or less followed through to the end, but the factory were just emptying the parts bins (remember by '81 they were pretty much shut down) so whatever they threw together was the spec.
In moking circles no-one really gets too excited about Californian or Standard, especially after 1980. Its too easy to fake one and too hard to prove it one way or the other. It doesn't make much difference to the value, anyway they're almost all Californians now, the stickers are quite cheap.
The one you show has the following features that suggest it was a Californian when it was made.
1) Denim look "tombstone" seats (the back should tip forward on an '81)
2) Sunraysia wheels (at least two anyway)
3) Californian bumpers
4) sports steering wheel, which looks roughly right for that year model.
5) Stickers
All of that can easily be swapped, but often you'll see most of the parts but not all of them tranferred over.
Mokes were "facelifted" around around '79/'80. After that all mokes were galvanised, also the fuel cap was moved to the side (a larger tank is fitted) the bumpers mount under the subframes rather than through the front panel, plus loads of small details. The 1275 became an option again at that time, along with 8.4" disks, the same as the 1275LS.
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
