It is currently Tue Jul 22, 2025 10:29 am
PostPosted: Sat Oct 27, 2007 12:48 pm
Heya fellas,
I'm tempted to replace the side trim on my Cooper S, as the current trim is beginning to come away in places due to a shitty job done by the car's previous owner (lots of nice deformed kinks that don't line up properly on the arch's for example).
I recall hearing that doing this is a royal pain in the balls. So can anyone give me some tips (and basically convince me) to go about doing the job myself?
I'm guessing the best thing to do is wait for a stinking hot day and lay the trim out in the sun for a few hours to soften it up.
PostPosted: Sat Oct 27, 2007 1:51 pm
yeah it comes rolled up and instead of fitting it with the natural curve going with the curve of the guard, you fit it upside down to assist in the bends onto the straight section
PostPosted: Sat Oct 27, 2007 5:04 pm
Put it in hot water to soften it up its much quicker. It wont matter what you do you will still get kinks in it till you have done it a few times
PostPosted: Sat Oct 27, 2007 5:06 pm
Hairdryer, carton of piss, couple of mates, and lots of patience - I tried all of them and there's still a couple of small kinks and little splits on a couple of the bends, but OK from 10' away :roll:
Happy with it seeing as it was my first go at it - hopefully get it better next time - one day :wink:
1982 Honda CB1100RC (ours)
PostPosted: Sat Oct 27, 2007 5:11 pm
maybe you need to lower your standards a bit...
then you won't have so much of a problem with kinks
PostPosted: Sat Oct 27, 2007 5:27 pm
Buy yourself a coupple of beer, take your time. Not really hard but quite painfull. A bit of glue does miracle. Done mine last week end. And if budget allows buy 3 :wink:
PostPosted: Sat Oct 27, 2007 6:18 pm
seriously this is the way. sadly i didnt get a photo no camera :cry:
Get the trim and if u have a clothes line run it along the longest wire that is on it, strill being patient with it though as it has been coiled up for ages. leave it for two days as im sure the time wont matter to u if u want it with no kinks. and seeing as they are $35 a side. :)
it will be plenty straight to go on. still be patient though as it is a bit tedious trying to get it on esperiously if u have flares. took no longer then and hour after that.
thats how i did it and its perfect. no kinks :D
PostPosted: Sat Oct 27, 2007 6:56 pm
its not to bad, I have grp 3? flares and I got it on without to many tears. I didnt heat it up or anything...it was 40 degrees that day though. Just take it slow and rivert it as you go.
blokeinamoke wrote:
PostPosted: Sat Oct 27, 2007 8:04 pm
Give Ash some flowers Nick .
Hot water and/or a hair dryer is the go. I have done it on my car and it is not a difficult job! It just requires alot of patience. To get it spot on I spent about 1.5 - 2 hours per side (I am a perfectionist).
I didn't bother putting mine in the sun though so if you do that it may be alot easier and take less time to put on.
PostPosted: Sat Oct 27, 2007 8:38 pm
Does it just snap on or do i need to buy some clips aswell?
PostPosted: Sat Oct 27, 2007 8:58 pm
I didn't use clips, it just fits on. It would almost stay there but I pop rivited it on to keep it in place because it would probably vibrate off without the pop rivits.
PostPosted: Sat Oct 27, 2007 9:08 pm
The proper Cooper S trim is held on with clips.
Pop rivets are for the plain type of trim fitted to the plain type of Minis.
I found years ago that there were two different brands of the Cooper S type trim. The dearer one was easy to fit, the cheaper one is still rolled into a tight roll even after 20 years. No amount of hot water, hair dryers or heat guns was ever going to straighten out the cheap one. :lol:
PostPosted: Sat Oct 27, 2007 9:17 pm
M1100, I held my trim on with pop rivits but I managed to get it straightened out. I paid $35 a side so is that the dear or cheap trim?
PostPosted: Sat Oct 27, 2007 9:28 pm
I just hate the way all this plastic trim shrinks in the Aussie sun, then looks like crap shortly befor it falls off.
The number of pieces is then 1 more than the number of pop rivets used. :lol:
Real Coopers (997s) had REAL S/S trim, 3 pieces per side. 8) Then BMC went cheap. :cry:
PostPosted: Sun Oct 28, 2007 1:09 am
it will need something to hold it on
