It is currently Sun Jul 20, 2025 8:31 am
 Post subject: Self parking wipers...
PostPosted: Thu Nov 01, 2007 12:49 pm
I need some wise advice about self parking wipers.
I just fitted a new wiper park plate but guess what, the wipers still won't self park..
Can anyone suggest why it is so???
PostPosted: Thu Nov 01, 2007 3:15 pm
Did they self park when you had your switches relocated? The wiring on the Clubby wipers is a tricky one.
The original switch had 5 contacts, or which 4 are used, No 3 is the one that isn't used. The switch switches to Earth, so the motor must have power.
The wires to the switch are as follows:
Pin 1 - Black/Green (Speed 1)
Pin 2 - Black (Earth)
Pin 4 - Red/Light Green (Speed 2)
Pin 5 - Blue/Light Green (Parking)
When Off, Pin 4 & 5 are bridged.
Speed 1, Pin 1 & 2 are bridged.
Speed 2, Pin 2 & 4 are bridged.
I'm attempting to recreate this with a 2 location toggle switch (similar to yours) and a Relay that has Double switching in it.
I'll let you know if I succeed.
Dicko.
PostPosted: Thu Nov 01, 2007 3:47 pm
d1ck0, the wipers have never self parked since I have had the LS even with the original switch.
I pulled the wiper motor off and apart and there was a fair amount of rust on the old wiper plate. Cleaned everything up but still a no auto stop.. :(
PostPosted: Thu Nov 01, 2007 4:05 pm
Hi Smokie,
There's an article about self parking or the auto stop in the mini encycleopedia somewhere if it's any use. I'll find it and post the link to it.
Try this mate http://www.ime.org.uk/ime/w/wiper_info.html
Hooroo
Rod Image
