It is currently Sun Jul 20, 2025 4:54 am
 Post subject: Cruise Control
PostPosted: Fri Oct 26, 2007 5:18 pm
Anybody installed cruise control on a Mini or Moke
 Post subject: Re: Cruise Control
PostPosted: Fri Oct 26, 2007 5:32 pm
Peg round the throttle cable :lol:
Or hook it up to your choke cable ... equally as fun :lol:
PostPosted: Fri Oct 26, 2007 5:48 pm
I have not fitted cruise to a Mini but I have fitted cruise to other cars.
There is no problem to fit it to a Mini. Couple of hours and about $200.
PostPosted: Fri Oct 26, 2007 5:51 pm
Not as much fun as a brick on the accelerator :D :D :D
PostPosted: Fri Oct 26, 2007 6:28 pm
Whilst you're at it Bloke, may as well put air conditioning in aswell.
:D
PostPosted: Fri Oct 26, 2007 6:50 pm
it's not about keeping the same throttle opening is it? you ahve to maintain the same speed up and down hills to?
PostPosted: Fri Oct 26, 2007 7:07 pm
The old analog kits used to simply maintain the manifold vacuum from what I remember seeing in an old pamphlet.
Keeping the same manifold vacuum meant maintaining the same engine load, I dunno how it went on hills however, must have been reasonable I guess or it wouldn't have sold..
 Post subject: Cruise control.
PostPosted: Fri Oct 26, 2007 7:23 pm
I have one in two of my cars. Great things they are. You cann drive and look at the sceenery an not having to keep your eyes on the speedo.
"Let us remove your "SHORTS"
PostPosted: Sat Oct 27, 2007 2:00 am
What aftermarket kits are there and does anyone have any reviews, prices etc?
PostPosted: Sat Oct 27, 2007 4:31 am
Are you really supposed to use cruise control on hills as opposed to just on long stretches of flat highways?
PostPosted: Sat Oct 27, 2007 6:50 am
Well it works fine on our Ford AU, up hills or not- it downshifts if needed. But of course it ain't smart enough to apply the brakes going downhill. :lol:
I really can't see the point of it in an underpowered 4 cylinder manual car though.
PostPosted: Sat Oct 27, 2007 8:28 am
underpowered?
PostPosted: Sat Oct 27, 2007 9:01 am
what about the hand throttle from a tractor, i heard some 4WD have them when bumping around
PostPosted: Sat Oct 27, 2007 9:45 am
Illegal for road use I think , some diesels have them for running PTO accessories like winches and things but not to use as a cruise control substitute .
PostPosted: Sat Oct 27, 2007 10:31 am
Yeah my motorbike had a factory fitted throttle lock screw. I used it once on the highway and then ripped it out and binned it. Problem was I forgot about it and only remembered after I had opened the throttle wide open to overtake and it stayed there....
