Info required https://www.ausmini.com/forums/viewtopic.php?f=2&t=37446 |
Author: | smokeingjoe [ Tue Nov 06, 2007 8:34 am ] |
Post subject: | Info required |
can anyone tell me if this is the correct charcaol canister for a 1978 leyland mini s. And if it is do you know where the third tube goes to, i only know about the one to the petrol tank and the big one to the rocker. cheers ![]() |
Author: | doogie [ Tue Nov 06, 2007 8:48 am ] |
Yes it is the right one for your model, 3 ports on top, one to the tank, one to the rocker cover & possibly one to the crankcase breather on the right side on the rear of the engine. Doogie |
Author: | drmini in aust [ Tue Nov 06, 2007 9:03 am ] |
No Doogie, on a `78 the crankcase breather goes to the vac port on the side of the HS4 carb. the 3 hoses on canister go to- fuel tank vent, rocker cover, float bowl vent on carby. ![]() |
Author: | doogie [ Tue Nov 06, 2007 9:08 am ] |
drmini in aust wrote: No Doogie, on a `78 the crankcase breather goes to the vac port on the side of the HS4 carb.
the 3 hoses on canister go to- fuel tank vent, rocker cover, float bowl vent on carby. ![]() Thats right Doc, was gunna edit my post about a second after you posted, no need now Doogie |
Author: | smokeingjoe [ Tue Nov 06, 2007 11:50 am ] |
thanks for the info. i can put it in properly now |
