It is currently Fri Jul 18, 2025 5:15 pm
 Post subject: petrol use
PostPosted: Sun Jan 02, 2005 8:57 am
What uses more fuel, twin 1.5' SU's or 45 weber? Just interested as I will be changing to weber shortly!
PostPosted: Sun Jan 02, 2005 9:20 am
It all depends on your right foot.
It's simple.... the harder you drive, the more fuel will use.
An engine will only use what it wants, theoretically there should be no difference between 2 different carbs.but the weber has accelerator pumps.
You will find you will use more fuel with the weber, coz it revs quicker and better
and you'll drive it harder
Miniworx Centre 0883741299
Online BMW Mini Shop
 Post subject: mini
PostPosted: Sun Jan 02, 2005 9:25 am
Bloody oath I will! No use having more power and not using it, hey!
PostPosted: Sun Jan 02, 2005 9:31 am
very true
once you get it on, bring it around and put it on the dyno.
only way to tune a weber 100 percent
