It is currently Fri Aug 22, 2025 1:22 am
 Post subject: few issues
PostPosted: Fri Nov 09, 2007 5:47 pm
hey everyone,
well my mini is up and running like a dream now,
but im having a few issues.
first my electrics have died,
I got an eftermarket temp gauge and it works ok,
but when i put my foot on the brake it dies and my alt light comes on, any ideas??
also Im getting a really bad ticking noice from what appears to be around the fan area but not sure where exactly?
any ideas on that one?
thanks,
Rick
PostPosted: Fri Nov 09, 2007 8:29 pm
Check the earth on your brake lights.
As for the ticking noise, can't really help you there.
2008 Prado GXL
PostPosted: Fri Nov 09, 2007 8:30 pm
Tickin noise could simply be the fan clipping the shroud.
PostPosted: Fri Nov 09, 2007 8:31 pm
This space for rent
That's good advice. I had problems with my indicators not working on one side with the lights or brakes on, turned out they were earthing through the brake light. I chased it for years, never twigged to the earth until recently.
PostPosted: Fri Nov 09, 2007 8:45 pm
yeah definitely sounds like and earthing fault.
ticking noise could be a lot of things can you explain the noise and narrow the spot down. one guess might be the alternator, as if they are ticking its time to replace the bushes or the regulator (just check the tension in the belt first to make sure that it is doing its job). could be anything though without narrowing it down - anything from valve clearances to drivetrain noise
PostPosted: Sat Nov 10, 2007 3:22 pm
well guys I have got mor einfo,
my headlights work fine,
parklights fine,
stereo fine.
no alt light coming on anymore,
no brake lights but I have tail lights,
no indicators any side.
and the ticking noise is only when the car gets warm
PostPosted: Sun Nov 11, 2007 8:03 pm
well i think I fixed the electrical problem,
replaced the two main fuses and clips,
seems to work fine now,
just gotta try find that ticking
oh it seems to be coming from fan area not in the engine
PostPosted: Tue Nov 13, 2007 3:45 pm
Grab hold of the radiator and push it backward and forwards while the engine is running, it should be rubber mounted. If it is the fan clipping the shroud the noise should change, get either louder or go away.
Another good way to investigate noises like that is to get a large screwdriver and put the big end against your ear then touch the small end on any suspect part (not moving parts of course). The noise will be amplified, it's a cheap stethoscope.
Touch it on the rocker cover and you will hear all the tappets and will know if the noise is coming from there. Water pump is another to investigate. Alternator. If you have a really long screwdriver you can get it down to the timing cover.
Pete
Users browsing this forum: No registered users and 241 guests
