It is currently Wed Aug 13, 2025 2:30 pm
 Post subject: fan
PostPosted: Sun Nov 11, 2007 11:19 am
what the best fan foor cooling the radiator in the mini.
im going to change radiator, water pump etc and thought why not.
there are a few on minisport and i just dont know.
though t id ask some pplz that might be in the know.
thanks
PostPosted: Sun Nov 11, 2007 11:50 am
You will get more opinions on here than there are different fans... :lol:
My 2 bob's worth- for road use I like the 16 blade metal one. 8) They are quieter than the plastic ones and don't fatigue & throw blades off when they get old.
It keeps my 1360 (86.6HP ATW) cool in hot weather, no probs. The radiator is a stock Mini Deluxe/Cooper S one, reconditioned. :wink:
PostPosted: Sun Nov 11, 2007 11:59 am
My 6 blade does a good job up here in the heat. Little bit noisy, but i can barely hear it over the exhaust/stereo.
PostPosted: Sun Nov 11, 2007 12:49 pm
Any fan works, some work better than others, but if you have a bad radiator or rusty waterways then all fans are useless. Just use the fan that came with your original engine as changing fans may mean needing to change radiator steady brackets and aquiring correct fan spacers.
PostPosted: Sun Nov 11, 2007 1:40 pm
nice..
ill go with the last . if it aint broke dont fix it :lol:
thanks all..
more money in the pocket
PostPosted: Sun Nov 11, 2007 2:06 pm
Plastic fan was on late roundies as well as all Clubbies.
Fans are all the same fitment, metal 16 blade vs plastic one etc- to use the alloy spacer or not depends on what you have already. If ya got one (ie in a Clubby) when you swap fans, keep it in. :wink:
Users browsing this forum: No registered users and 174 guests
