What to take on a road trip https://www.ausmini.com/forums/viewtopic.php?f=2&t=37640 |
Page 1 of 3 |
Author: | d1ck0 [ Sun Nov 11, 2007 8:17 pm ] |
Post subject: | What to take on a road trip |
Well there's 4 weeks till Watto's Grand Day Out and we're starting to get ready for the drive down. What should I take on the trip to cover the unforseen that may happen. Obviously cant take spaers for everything but would like to cover some things. Obviously will take: Spare Water Spare Fuel Gaffa Tape Electrical Tape Fan Belt Fuses Globes What else? I'd prefer reasonable answers but I know some of you won't be able to help yourselves. Dicko. |
Author: | drmini in aust [ Sun Nov 11, 2007 8:21 pm ] |
Throttle cable... Wheel brace if you don't have one. |
Author: | peter1 [ Sun Nov 11, 2007 8:24 pm ] |
Jack (the kind that lifts cars....) Mobile phone. |
Author: | Mike_Byron [ Sun Nov 11, 2007 8:25 pm ] |
Assuming you are taking the toolbox then radiator hoses. Actually the more bits you cram into the car the less likely you are to have a break down. |
Author: | Harley [ Sun Nov 11, 2007 8:26 pm ] |
Random suggestions: Money Grease More than one 1/2" spanner Spare wheel nuts Lots of CDs Cable ties: lots of them WD40 Clean rags |
Author: | d1ck0 [ Sun Nov 11, 2007 8:28 pm ] |
drmini in aust wrote: Throttle cable.... About to change that as it now operates in steps, but will take a spare as well.
Spare Wheel, Jack, Wheel Brace etc are all there (normally so didn't mention them). Brake Fluid & Spare Oil too of course. Dicko |
Author: | 1018cc [ Sun Nov 11, 2007 8:46 pm ] |
Yeah I would recommend it, I snapped mine the other day. |
Author: | doogie [ Sun Nov 11, 2007 8:55 pm ] |
Car trailer. Doogie |
Author: | Morris 1100 [ Sun Nov 11, 2007 8:56 pm ] |
My theory is the more you take the more likely that the car will have problems dragging aroung a boot load of ballast. Take some wire (coat hanger style) and pliers, if you need to fix exhaust mounts on the way it is handy to have some wire (you can usually find wire on a farmers fence but they get annoyed if the sheep get out) I just did a big road trip in my wifes Ford Telstar (1988 2.2 auto, it was free when I worked at a wrecker) I took oil, water, coolant, brake fluid, degreaser, silicone spray, windscreen cleaner, WD40, washer additive, plumbers tape, cloth duct tape, insulation tape, thin tie wire, thick tie wire, metric tools, screwdrivers, a file, rope, paper towel, hand cleaner, rags, etc. I only used half a litre of oil and the windscreen cleaner and rags. ![]() |
Author: | Kennomini [ Sun Nov 11, 2007 8:58 pm ] |
points, condenser, coil, leads, plugs you never know when 'Lucas' will pop in for a visit ![]() ![]() |
Author: | gafmo [ Sun Nov 11, 2007 8:59 pm ] |
Start ya Bastard |
Author: | Hanra [ Sun Nov 11, 2007 9:02 pm ] |
A good torch if driving at night. |
Author: | Smokie [ Sun Nov 11, 2007 9:13 pm ] |
Join the NRMA?? |
Author: | simon k [ Sun Nov 11, 2007 9:17 pm ] |
I work on the theory that whatever I don't take with me, is what I'll need... so when I do a long trip, I take EVERYTHING well... everything in the way of tools at least, but one of the most important things to take with you is an NRMA membership - it's a get out of jail free card - even if the person who comes to help you doesn't know one end of a screwdriver from the other, at least they're likely to have said screwdriver, some bits and bobs, and will give you a tow if you need it I had RACV tow me home from the supermarket a couple of months ago when my starter motor shat itself - I rang them, and they sent a truck... too easy PM me for my mobile number, if you get to near the Vic/NSW border and need help, I'll do anything I can, and can get you anything you'd need - or even just a beer or three ![]() |
Author: | Morris 1100 [ Sun Nov 11, 2007 9:26 pm ] |
skssgn wrote: I had RACV tow me home from the supermarket a couple of months ago when my starter motor shat itself - I rang them, and they sent a truck... too easy Ya big baby. I drove my LS around without a starter for a week while I was getting it re-built. You just give it a push and jump in. ![]() Oh, yeah d1ck0, PM me for my mobile number, the more numbers you have the less chance of getting stuck in the middle of nowhere. |
Page 1 of 3 | All times are UTC + 10 hours |
