My Mini has a rattle?? https://www.ausmini.com/forums/viewtopic.php?f=2&t=37644 |
Author: | roofilicious [ Sun Nov 11, 2007 10:27 pm ] |
Post subject: | My Mini has a rattle?? |
hey guys my mini has developed a severe rattle in the left wing valance somewhere and i cant seem to find the little bugger, its a 1965 cooper s, any ideas? common occurance? Roofie |
Author: | mad-mk1 [ Mon Nov 12, 2007 12:28 am ] |
its old old things rattle i cant help though sorry |
Author: | MiniMe87 [ Mon Nov 12, 2007 6:37 am ] |
the easiest way of fixing the rattles is to turn the radio up ![]() |
Author: | 1018cc [ Mon Nov 12, 2007 8:31 am ] |
I know where you're coming from, I have subsequently fixed every rattle/vibration in my car and it is amazing how much better it feels to drive (I drive without a radio ![]() I would just suggest grease things up (work those grease nipples ![]() Does the noise only happen when turning? Adjusts with speed? Just going over bumps etc? Or does it happen all the time? |
Author: | roofilicious [ Mon Nov 12, 2007 1:39 pm ] |
lols no radio to turn up.. its a rev rattle that happens around 2000 breifly and again at 3000 for a bit longer.. it sounds like something loose in the engine bay but i cant put my finger on it.. |
Author: | doogie [ Mon Nov 12, 2007 1:47 pm ] |
Check your bonnet badge, my MK1 Cooper S bonnet badge vibrates like mad, but im too lazy to fix it. Doogie |
Author: | Kennomini [ Mon Nov 12, 2007 6:54 pm ] |
check your radiator surround, it may have lost a screw, mine rattles at certain revs but I do have a radio ![]() Ignorance is bliss ![]() |
Author: | drmini in aust [ Mon Nov 12, 2007 7:20 pm ] |
Check the bonnet is not touching the metal body on the sides, or at the front. |
Author: | roofilicious [ Mon Nov 12, 2007 9:10 pm ] |
i think i found it but not 100% sure need someone to give me a hand i cant rev and hold things at the same time but i am pretty sure the radiator is vibrating against the mount at the back, easy fix but i had only checked the front end because thats where there is a small amount of paint wear. will fix it in the morning before school haha.. Roofie |
