are these what id need to fix my concern?
https://www.ausmini.com/forums/viewtopic.php?f=2&t=37701
Author:  sociallydisabled [ Tue Nov 13, 2007 11:49 am ]
Post subject:  are these what id need to fix my concern?
when i rebuilt my subframe to undo the brackets holding on the traiiling arms required an accidental breaking of the nuts welded to the inside of the frame. to fix that problem i have used new nuts and bolts, but couldnt get a welder in there to secure them, now ive found that the tyre seems to be dirty fromt eh concrete in my shed, but not all the way across. and i feel it is due to my brackets moving when i put things together, should i remove the brackets and just put them back on. or. buy these and be donr with it? andyone else had this problem? http://www.minisport.com.au/prod19.htm
Author:  simon k [ Tue Nov 13, 2007 11:52 am ]
probably.... and you'll need to get the rear wheel alignment done properly by a wheel alignment joint
Author:  JC [ Tue Nov 13, 2007 12:22 pm ]
Yeah, i don't think thats going to fix your problem. With the nuts 'loose' you could fix (make permanent) the amount of camber to counter the movement of the nuts/bolts. But whats to say that the nuts/bolts won't move in the other direction giving you too much positive or negative camber? ning nong of a thing to happen but I reckon you need to weld the captive nuts back on.
Author:  sociallydisabled [ Tue Nov 13, 2007 5:59 pm ]
i think ill need to do both :) as i think re welding will still mess with the alignment, and i can stop my car crabbing if it does, cos that looks shocking haha, thanks guys 8)
