Have you got the separate limiting valve below the master cylinder? If so check that fluid comes out of the outlet when you bleed it, just to cancel it out.
I have heard that with the twin circuit master cylinders you need to bleed both the front and rear (of the same side) at the same time, but of course that requires an extra person.
Also make sure it isn't your technique that is causing problems. If you do the pump-pump-pump hold method, then you get enough pressure in the system to activate the limiting valve, so no fluid comes out the back. This happens on single circuit too.
