It is currently Fri Aug 22, 2025 7:32 pm
PostPosted: Tue Nov 13, 2007 11:49 am
when i rebuilt my subframe to undo the brackets holding on the traiiling arms required an accidental breaking of the nuts welded to the inside of the frame. to fix that problem i have used new nuts and bolts, but couldnt get a welder in there to secure them, now ive found that the tyre seems to be dirty fromt eh concrete in my shed, but not all the way across. and i feel it is due to my brackets moving when i put things together, should i remove the brackets and just put them back on. or. buy these and be donr with it? andyone else had this problem? http://www.minisport.com.au/prod19.htm
I have a problem.. apparently
PostPosted: Tue Nov 13, 2007 11:52 am
probably.... and you'll need to get the rear wheel alignment done properly by a wheel alignment joint
PostPosted: Tue Nov 13, 2007 12:22 pm
Yeah, i don't think thats going to fix your problem. With the nuts 'loose' you could fix (make permanent) the amount of camber to counter the movement of the nuts/bolts. But whats to say that the nuts/bolts won't move in the other direction giving you too much positive or negative camber? ning nong of a thing to happen but I reckon you need to weld the captive nuts back on.
PostPosted: Tue Nov 13, 2007 5:59 pm
i think ill need to do both :) as i think re welding will still mess with the alignment, and i can stop my car crabbing if it does, cos that looks shocking haha, thanks guys 8)
Users browsing this forum: No registered users and 311 guests
