CUB wrote:
Mate it sounds like the selector rail bolt has come loose and dropped out in the gearbox. The locknut works loose on remote boxes and falls out, so you guess what you have to do now
Rod change boxes had a roll pin instead of a bolt,locknut and shakeproof washer.
If you do have to pull it apart and fix, use locktite on the bolt with the locknut.
you know how much i both hate and love you right now?
i tightened up the linkages and still the same.
seriously thinking about selling all i seem to have is problem after problem
edit:
If you can get gears with the engine turned off and not when it is running it would most likely be the clutch. Telltale would be if the clutch takes up down near the floor. It should take up about 2/3 of the way out. Poor clutch adjustment can cause drag on the synchros which can stop it going into gear with the engine running.
im not sure if it is selecting 1st and second but i can move the shifter through the normal H pattern, if i have it in 1st or second theoretically and start the car it isnt in gear when i release the clutch it does nothing
