It is currently Sat Jul 19, 2025 5:36 am
 Post subject: Crankshaft ID
PostPosted: Thu Nov 15, 2007 6:29 pm
Have a crankshaft,cast ID is ESC2A,can anybody help please,and would it be any good for a good rebuild. Thanks
Hopefully the front end always goes first. Rob
PostPosted: Thu Nov 15, 2007 6:35 pm
That is just a casting number, look for a stamped number on one of the webs so we can ID it. Or measure the main bearing and crankpin journals.
Any crank is good for a rebuild if it's not been reground too many times, is not cracked and has a good condition taper on the tail where the flywheel fits.
PostPosted: Thu Nov 15, 2007 6:47 pm
if it came out of your car, you'd be hoping it's a MK1 S crank - should have EN40B cast into it somewhere, and I forget the proper number for a '68 S, but it'll be one of AEG315, AEG316, AEG479 or AEG480
PostPosted: Thu Nov 15, 2007 6:51 pm
Thanks,only stamp is 372,mains approx 2 inch,bigend 1-5/8".Only have a steel rule but that was as close as I could get. Cheers
PostPosted: Thu Nov 15, 2007 6:55 pm
No,it came with a 1275 block I picked up. Cheers
PostPosted: Thu Nov 15, 2007 7:03 pm
sounds like a standard 1100S crank then... you need to measure it properly...
if it's going in your S motor, it'll need thicker thrust bearings than standard ones
PostPosted: Thu Nov 15, 2007 7:07 pm
+.030"... which you can't get from UK now, but ACL still makes `em out here. :D
I bought a set from www.minis.com.au
PostPosted: Thu Nov 15, 2007 7:34 pm
Thanks guys. Cheers
