Alternator Question
https://www.ausmini.com/forums/viewtopic.php?f=2&t=37815
Author:  Toasted [ Thu Nov 15, 2007 7:02 pm ]
Post subject:  Alternator Question
I have with me what i believe is an 17ACR alternator that i took off my 1275, i say i belive only cause there is a tag on the outside of it but it looks very similar to the other one i have which is supposed to be the original one.
What is the original alternator?
I bought a replacement some time ago, which i think is a 16ACR?
Time to get another one, Which one should i recondition??
Thanks in Advance
Author:  Mike_Byron [ Thu Nov 15, 2007 7:11 pm ]
A number of mini outlets sell a 75 amp hour bolt on alternator and as well that there are other make alternators that can be made to fit.
The original alternator is a 35 amp hour that just doesn't provide enough power to modern equipement (h4 lights, stereos not to mention laptops and DVD players - all modern essential equipement.
Unless you need absolute originality check with any of the mini suppliers. Reco'ing your existing 35 amp hour will be about the same price as an upgrade.
Mike
Author:  simon k [ Thu Nov 15, 2007 7:28 pm ]
Mike_Byron wrote:
35 amp hour
is that how they're rated? amps per hour, I'm assuming at a standard RPM or .. ?
Author:  Mike_Byron [ Thu Nov 15, 2007 7:31 pm ]
skssgn wrote:
Mike_Byron wrote:
35 amp hour
Yep - but unsure why or how - Doc ????
Author:  Toasted [ Thu Nov 15, 2007 7:41 pm ]
Ok so i should reco the 17ACR cause it has a higher amp output?
Any possible problems by using this Alternator?
Author:  steve1965 [ Thu Nov 15, 2007 7:52 pm ]
I have changed my alternator and i now use a EA Falcon alternator it is 85 Amps best mod ever. :lol:
Steve
Author:  albino235 [ Thu Nov 15, 2007 8:08 pm ]
I'm pretty sure they would be rated at amps not amp hours...
eg. they nominally put out 75amps of current constantly, this is a lot of current
A battery on the other hand is rated in amp hours
eg. a 1 amp hour battery can provide 1 amp for an hour
So a 75 amp alternator will put out probably an average of 30 amps under normal driving conditions. To get watts, you go volts times amps, or 12x30 = 360Watts so you should be able to run around 300 watts of equipment without leaving your battery uncharged...
But I am no electric engineer :wink:
Author:  sgc [ Thu Nov 15, 2007 10:50 pm ]
Even so, you've got it pretty much right 8)
