Battery Cover https://www.ausmini.com/forums/viewtopic.php?f=2&t=37831 |
Author: | Wombat [ Fri Nov 16, 2007 9:53 am ] |
Post subject: | Battery Cover |
Can someone give me the dimensions of the original battery cover please? I have an idea of making one out of a hard plastic battery box but need a starting point so basically the depth of the narrow side and the depth the deep side and length of any horizontal side bits. Taa |
Author: | Rodney [ Fri Nov 16, 2007 12:27 pm ] |
Sure......... Length 328 mm Wide 200mm Left bit 110mm right bit 45mm at both ends, but the centre measurement is 30mm ............therefore, you have an 'angle from each end that is 45mm from each end (Does that make sense???? ![]() Now, the two ends are simply a diagonal line but with cut outs for the retaining strap and +ve and -ve battery leads. Have fun ![]() |
