It is currently Mon Jul 28, 2025 10:40 am
 Post subject: Sender guage..
PostPosted: Sat Nov 17, 2007 8:23 am
When fitting a 35Lt fuel tank does one need to fit a new sender guage or will the old one suffice with a bit of modification?
At the moment, the fuel guage shows only 1/2 full when the tank is really full..
PostPosted: Sat Nov 17, 2007 10:11 am
It it the screw mounted or bayonet fit? If screw you may have it out by a hole. Also check the float doesn't have a leak
PostPosted: Sat Nov 17, 2007 10:15 am
T'is the bayonet type and the float was clear when I put it in..
PostPosted: Sat Nov 17, 2007 10:17 am
How many lugs on the bayonet - 2 or 3 - if 3 still could be out a 1/3 of a turn
PostPosted: Sat Nov 17, 2007 10:20 am
A 3 lugged type and I will have to wait until the tank empties a bit before I go and fiddle with it tho..
PostPosted: Sat Nov 17, 2007 11:34 am
Depends on wheteher you've got any muck you want to clean off the boot floor :shock:
Dicko
PostPosted: Sat Nov 17, 2007 11:47 am
d1ck0, no muck on the boot floor after the last 10Lts cleaned it up when I didn't have the sender lug done up properly when I fitted the tank... :?
Users browsing this forum: fuzzy-hair-man and 84 guests
