Sender guage.. https://www.ausmini.com/forums/viewtopic.php?f=2&t=37863 |
Author: | Smokie [ Sat Nov 17, 2007 8:23 am ] |
Post subject: | Sender guage.. |
When fitting a 35Lt fuel tank does one need to fit a new sender guage or will the old one suffice with a bit of modification? At the moment, the fuel guage shows only 1/2 full when the tank is really full.. |
Author: | Wombat [ Sat Nov 17, 2007 10:11 am ] |
It it the screw mounted or bayonet fit? If screw you may have it out by a hole. Also check the float doesn't have a leak |
Author: | Smokie [ Sat Nov 17, 2007 10:15 am ] |
T'is the bayonet type and the float was clear when I put it in.. |
Author: | Wombat [ Sat Nov 17, 2007 10:17 am ] |
How many lugs on the bayonet - 2 or 3 - if 3 still could be out a 1/3 of a turn |
Author: | Smokie [ Sat Nov 17, 2007 10:20 am ] |
A 3 lugged type and I will have to wait until the tank empties a bit before I go and fiddle with it tho.. |
Author: | d1ck0 [ Sat Nov 17, 2007 11:34 am ] |
Smokie wrote: A 3 lugged type and I will have to wait until the tank empties a bit before I go and fiddle with it tho.. Depends on wheteher you've got any muck you want to clean off the boot floor ![]() Dicko |
Author: | Smokie [ Sat Nov 17, 2007 11:47 am ] |
d1ck0, no muck on the boot floor after the last 10Lts cleaned it up when I didn't have the sender lug done up properly when I fitted the tank... ![]() |
