Removing the Windscreen Wiper Motor https://www.ausmini.com/forums/viewtopic.php?f=2&t=3792 |
Author: | MiniK [ Tue Jan 04, 2005 3:50 pm ] |
Post subject: | Removing the Windscreen Wiper Motor |
Ive unbolted her, and taken of the connection at the bundy pipe connection but the bloody cable wont come out!!!. Do i pull it out through the bundy tube or should it simply come out through the motor? Im guessing ive missed something again ![]() |
Author: | gafmo [ Tue Jan 04, 2005 4:04 pm ] |
Post subject: | Re: Removing the Windscreen Wiper Motor |
MiniK wrote: Ive unbolted her, and taken of the connection at the bundy pipe connection but the bloody cable wont come out!!!.
Do i pull it out through the bundy tube or should it simply come out through the motor? Im guessing ive missed something again ![]() I'm with you a just left it for the last 4 weeks ![]() |
Author: | MiniK [ Tue Jan 04, 2005 4:06 pm ] |
I want mine out tonight though ![]() Then I can mount him on the rotisserie ![]() |
Author: | 13secmini [ Tue Jan 04, 2005 4:19 pm ] |
undo the 4 screws holding the motor cover on and the cable will come out. |
Author: | aaron [ Tue Jan 04, 2005 5:00 pm ] |
as 13 sec said, you have to take the cover off and remove the cable from the pin that holds it to the motor. Tricks of the trade! Haha Cheers Aaron |
Author: | MiniK [ Tue Jan 04, 2005 5:53 pm ] |
aaron wrote: Tricks of the trade! Haha
Bloody oath.... ![]() Thanks fellas....i managed to mount it anyway. Just gotta disconnect the cable tomorrow ![]() |
Author: | drmini in aust [ Tue Jan 04, 2005 6:45 pm ] |
Hi, jack...... Barney has the early wiper rack and wheel boxes, but a 2 speed Clubbie motor in there.. It wipes fine but the wipers do 180* right across the screen. ![]() Can the later wheel boxes be fitted to an early car, so they wipe properly? Anyone done it? ![]() /Hi, jack ![]() |
Author: | MiniK [ Tue Jan 04, 2005 8:06 pm ] |
drmini in aust wrote: Hi, jack......
Barney has the early wiper rack and wheel boxes, but a 2 speed Clubbie motor in there.. It wipes fine but the wipers do 180* right across the screen. ![]() Can the later wheel boxes be fitted to an early car, so they wipe properly? Anyone done it? ![]() /Hi, jack ![]() Oi ![]() |
Author: | gafmo [ Tue Jan 04, 2005 9:10 pm ] |
You don't ese that every day. |
Author: | aaron [ Tue Jan 04, 2005 9:14 pm ] |
only way to fix it kev is to use the wheel boxes from a clubby. You may also need to use the inner thingy(can't think of the word) to make it right gear ratio. Cheers Aaron |
Author: | drmini in aust [ Tue Jan 04, 2005 10:23 pm ] |
aaron wrote: only way to fix it kev is to use the wheel boxes from a clubby. You may also need to use the inner thingy(can't think of the word) to make it right gear ratio.
Cheers Aaron Thanks Aaron, The whole motor & box is a Clubby one, crank and all. I have a full Clubby wiper setup spare, need to find an old 850 or Deluxe one so I can sort out these mods before I actually fit them. ![]() ![]() |
Author: | simon k [ Wed Jan 05, 2005 10:01 am ] |
drmini in aust wrote: aaron wrote: only way to fix it kev is to use the wheel boxes from a clubby. You may also need to use the inner thingy(can't think of the word) to make it right gear ratio. Cheers Aaron Thanks Aaron, The whole motor & box is a Clubby one, crank and all. I have a full Clubby wiper setup spare, need to find an old 850 or Deluxe one so I can sort out these mods before I actually fit them. ![]() ![]() good on you Doc - you can tell me how to set it up - my engineer says I've gotta have 2 speed wipers, I was thinking I'd need to drill holes in the wiper panel to fit the whole clubman assembly when I do it on the van ... |
