It is currently Sun Aug 10, 2025 4:01 am
 Post subject: Subframe mount nut size?
PostPosted: Mon Nov 19, 2007 8:24 am
Hi all
I have a 67 deluxe with hydro, and the subframe from a 70 K (dry).
The 2 subframes have different size top mount nuts.
Hydro with 5/16 UNF & dry with 3/8 UNF.
Is this correct or have the wrong size nuts been put in the hydro subframe?
Also should I stitch weld around the top mount plate even if it has no cracks?
PostPosted: Mon Nov 19, 2007 8:40 am
cd wrote:
Hi all
deleted everything - utter lunacy!!
PostPosted: Mon Nov 19, 2007 9:32 am
So, can I get studs with 5/16" both ends?
Or, look at if it is possible to remove the 5/16" nuts in the subframe & replace the with 3/8" nuts?
PostPosted: Mon Nov 19, 2007 9:39 am
ahhh!!!! sorry!!!
anyone reading my post above would think I'm a complete loony!!
hydro subframes used 5/16" bolts through the crossmember, dry subframes used those stepped 3/8" to 5/16" studs
go to a bolt place and buy a big long unf bolt... I'll give you the size in 5 minutes
PostPosted: Mon Nov 19, 2007 9:47 am
the hydro subframe bolt is 4 1/4" long (without the head) of that, the first 1" is threaded.
a while ago I bought some high tensile ones at my local coventry fasteners that did the job, I have several of the original ones too
sigh... I've got a mind like a steel trap, rusty and squeaky
PostPosted: Mon Nov 19, 2007 10:08 am
cd,
There's no such thing as a 70 K dry subby, they were all wet. If it's got studs either the subby is from something else, 850, van or whatever- or the bolts have been replaced by studs.
PostPosted: Mon Nov 19, 2007 10:10 am
cd,
I had that in my first post that I deleted.... along with a lot of crap :roll:
