It is currently Thu Aug 14, 2025 5:48 am
 Post subject: HIF 44
PostPosted: Mon Nov 19, 2007 7:09 pm
How the hell do you adjust the mixture?
Pics would be good as i have the retardation :lol:
Cheers Anthony.
PostPosted: Mon Nov 19, 2007 7:16 pm
I is a mookenik
from what i was told u cant do it from the outside. u have to re adjust the float and thats all
PostPosted: Mon Nov 19, 2007 7:26 pm
There's a screw in the side, so they say...
HIFs are too new for me, I'm an HS2-4-6 man. :lol:
it is on the back/side (at angle) of carb down near float bowl and under fuel inlet (if looking from engine side of carb it will be on rear left) there is a small screw inside a shroud anti clockwise is leaner clockwise is richer
PostPosted: Mon Nov 19, 2007 7:44 pm
ausmini mod
ausmini mod
This Link to HIF44 might help.
Pete.
PostPosted: Mon Nov 19, 2007 7:51 pm
PostPosted: Mon Nov 19, 2007 8:48 pm
Found it! Thanks for the help boys.
PostPosted: Mon Nov 19, 2007 8:53 pm
on a Mini as per above on the location but you need a Short flatty to turn it
PostPosted: Mon Nov 19, 2007 9:02 pm
Mine's flatty or phillps head. Adjust it slowly, quarter of a turn at a time until your close, then fine tune. A little turn goes a long way.
PostPosted: Tue Nov 20, 2007 7:37 am
Yep looking into engine bay its on the left hand side pointing to the bulkhead. turn in to pull jet down to richen mixture and turn out to pull jet up to lean out. you may need to cut a stumpy flat blade to fit in there as it is a tight fit also a bit tricky when tuning with a camy engine moving around a bit
Users browsing this forum: Bing [Bot] and 276 guests
