clutch diaphram spring?
https://www.ausmini.com/forums/viewtopic.php?f=2&t=38000
Author:  suffolk [ Tue Nov 20, 2007 9:22 pm ]
Post subject:  clutch diaphram spring?
What the best colour code for a worked 1275 's' motor? I currently have a blue spring would it be strong enough or should i go for orange? Does it matter that much or do they slip if not right? cheers
Author:  TheMiniMan [ Tue Nov 20, 2007 9:27 pm ]
Orange is pretty strong (Race/rally) type thing,,, if you choose to use it then STAY OFF the clutch as much as possible & try not to ride it at all.
The grey is basically the strongest of the factory type & they are pretty well full race only & i definately don`t recomend them for road use at all
the Dark blue should be fine for you ...---> as long as it`s all sweet & set up right.
Which-ever one you decide on, make sure you have it all set up so that the throw out bearing isn`t running on the clutch the whole dam time,,, the amount of throw out bearings that people commonly & frequently replace is simply due to mal adjustment (over adjustment) BECAUSE of another "THROW" or inadequate "TRAVEL" problem that hasn`t been sorted properly.
Author:  suffolk [ Tue Nov 20, 2007 9:32 pm ]
Thanks for that miniman,,,I'll stick with the blue one i have..just thought i'd ask the question before i put it in...Is there anything i should know putting a new timken thrust bearing on, ive never done it before? cheers
Author:  drmini in aust [ Tue Nov 20, 2007 9:34 pm ]
It goes on the same as the later one does. But lasts longer. :wink:
Don't bash on the thrust face when fitting it, use a press.
Author:  suffolk [ Tue Nov 20, 2007 9:36 pm ]
Any clearances or just flush with the plunger 'rod'? cheers
Author:  suffolk [ Tue Nov 20, 2007 9:38 pm ]
Just noticed it on a shouldered shaft should be no drama's..thanks for all your help guys...
Author:  drmini in aust [ Tue Nov 20, 2007 9:54 pm ]
I agree with Matt, a dark blue diaphragm should be fine. I ran one in my well worked 1310 for years.
Make sure diaphragm spring is flat when bolted up. see here- http://www.minimania.com/web/DisplayID/ ... ticleV.cfm
Author:  suffolk [ Tue Nov 20, 2007 10:05 pm ]
Thanks DOC!!
Author:  Mick [ Tue Nov 20, 2007 10:09 pm ]
With an unidentified plate (the paint spot is missing) can I measure the diaphragm spring thickness wit ha micrometer to get an idea of what it is? or does the plate's metalurgy/design change?
Author:  drmini in aust [ Wed Nov 21, 2007 5:40 am ]
Measure it and I'll measure a blue dot one too. :wink:
Author:  Mick [ Wed Nov 21, 2007 7:15 am ]
I measured the one I have here (from the S engine) and got and average around the plate of .090 of an inch. This was a little in from the inner edge because of the wear that occurs here.
