Ziegech wrote:
i had a sticking carby 1.25 twin Su so i got some dry glide teflon lube in them (i have gravity not spring carbs)
can you explain what you mean by "gravity" as opposed to "spring" carbs. All SU carbs should have a spring inside the dashpot pushing the piston down to the bridge.
Also, do you have oil in them?
Ziegech wrote:
i also noticed the little disk for the vac advance on the top of the dizzy is loose and can move up and down.
can't you tighten that up with the distributor cap off? while you're fiddling with that, pull the hose off the carb end of the hose that goes to the vacuum unit and suck on it (with your mouth) - it should be sealed up, (and if you suck really hard, it'll move the rod that goes into the distributor)
Ziegech wrote:
i noticed also my idle is changing from 500 to 800 to 1000 at different times.
i dont know what a vaccum leak is or if its the cause
Simply put, a vacuum leak is where there is an air leak on one of the tubes coming off the inlet manifold. Engines suck air into the cylinders as they run, when the throttle(s) are closed, the suction produced by the pistons produce a vacuum in the manifold (which can be used by various things - boosters, carb advances), if there is a vacuum leak, then it means there's air getting in to the motor when there shouldn't be.... if the leak is variable (blocking and unblocking), then the idle will go up and down. It will have a higher idle when there is air leaking in to the manifold, until the point where there is more air getting in there than is coming through the carbs, and it leans out to the point the motor stalls
Ziegech wrote:
but now after all this the lumpy fourth has dissappeared and first gear is bogging down on take off to the point of stalling occasionally so i have to rev her up to take off???
on face value of what you've said, you might find that the vacuum unit is stuffed and leaking a lot..... take it off completely, put some tape over the hole in the distributor, and block off the hole in the distributor where the hose goes
did I tell you that I won a
trophy?
