It is currently Tue Jul 22, 2025 8:08 pm
PostPosted: Fri Nov 23, 2007 2:51 pm
Heyas,
The dizzy has been removed from my 1275 and the engine has been turned over in the meantime. When im refitting it would it just be a case of getting the engine to TDC and inserting the dizzy with the vac advance on the top and the rotor pointed at 2 o'clock (spark plug of cylinder 1)?? Or is there something else needed since the engine has been turned over with the dizzy out?
Cheers for the help,
Dave
PostPosted: Fri Nov 23, 2007 3:14 pm
Make sure number 1 & 4 are at TDC and the rockers on number 4 are rocking. Then the rotor should point to cylinder 1.
Users browsing this forum: drmini in aust and 92 guests
