165 tyres on std drums
https://www.ausmini.com/forums/viewtopic.php?f=2&t=38106
Page 1 of 2
Author:  aaron [ Fri Nov 23, 2007 4:21 pm ]
Post subject:  165 tyres on std drums
Anyone want to shed stories of ill fit or all good, on weather or not 165x10's will fit under the guards of a non flared, non S offset drum's(all round) wrapped around a set of std Cooper S steelies? Anyone?
Aaron
Author:  poeee [ Fri Nov 23, 2007 4:22 pm ]
You'd have to fit spacer drums.
Author:  aaron [ Fri Nov 23, 2007 4:43 pm ]
my understanding, is the offset drum will push the rim to needing flares. no offest will rub inside on the various arms etc. so some spacers machined down to half would work better yes?
Aaron
Author:  smac [ Fri Nov 23, 2007 4:53 pm ]
On anything up to 4.5" wide 145's will look and handle better.
Author:  Morris 1100 [ Fri Nov 23, 2007 5:07 pm ]
On the rear they will rub the trailing arm.
They will also make the car very squirmy to drive. Not good and not recommended. :cry:
Author:  aaron [ Fri Nov 23, 2007 5:31 pm ]
hmmm interesting. other than falkens, what else is available in 145's that is half decent.
Aaron
Author:  poeee [ Fri Nov 23, 2007 5:37 pm ]
You can get Bridgestone SF226 145's in a 12... can you get them in a 10?
Author:  cush [ Fri Nov 23, 2007 5:58 pm ]
sorry to disappoint you gents...
on the rear is a bridgestone 165 on a 5 or so inch widended steel rim on a non-spacered drum sitting, as i can see, nicely under the arch..
without rubbing
Author:  smac [ Fri Nov 23, 2007 6:01 pm ]
Cush unless it's a widened S rim you're talking different inset figures.
Author:  poeee [ Fri Nov 23, 2007 6:04 pm ]
BAM!
I know for a fact that a Clubman S rim (same offset as an S rim) will foul without spacer drums on the back.
Author:  jbeenz [ Fri Nov 23, 2007 6:22 pm ]
Hijack here,
are we saying that a 165/12 on a 4.5in rim, will drive worse than a 145 ?
Author:  cush [ Fri Nov 23, 2007 6:26 pm ]
i'm just answering the man's question.. ;)
you can't talk about offset :)
Author:  poeee [ Fri Nov 23, 2007 6:33 pm ]
Author:  cush [ Fri Nov 23, 2007 6:46 pm ]
poeee wrote:
i didnt' say which man... :)
Author:  smac [ Fri Nov 23, 2007 6:51 pm ]
jbeenz - I think we're talking 10's, but yes, that's been my experience. You can feel the sidewall flex in a 165 on a 4.5" rim.
