It is currently Sat Jul 19, 2025 9:21 pm
 Post subject: stall and die
PostPosted: Sat Nov 24, 2007 10:21 am
No matter how many revs you give it - its stalls as you try to move off.
The pedal height is fine and you can feel friction point.
It was fine three days ago and hasnt been driven very far since.
Just canvasing ideas before I pull the clutch apart again.
PostPosted: Sat Nov 24, 2007 10:37 am
how's the mixture?
is there an air/fuel blockage?
how's the timing?
Mod Inclusion: Try releasing the handbrake.
PostPosted: Sat Nov 24, 2007 10:43 am
cush wrote:
how's the mixture?
mabye a little rich
nup
cush wrote:
how's the timing?
about 11:42 :P
fine-ish
but none of that has changed in three days
PostPosted: Sat Nov 24, 2007 11:36 am
Will the moke roll by itself or is a brake jammed on somewhere , is there anything (lost spanner or screwdriver) jammed in your rubber uni's , look for anything odd at this stage before stripping the clutch .
PostPosted: Sat Nov 24, 2007 11:43 am
rolls by itself. It drives down hill. As soon as you apply load it stalls
Mixture has no effect - have tried a little lean to quite rich to no effect.
the clutch is not overthrowing.
PostPosted: Sat Nov 24, 2007 11:48 am
Check your electrical connections , is a wire held tight anywhere , is one squashed anywhere , anything that would be affected by the engines slight movement when it's under load ?
PostPosted: Sat Nov 24, 2007 12:04 pm
the electrics are all behaving as inteneded.
If I put into neutral quickly enough it will avoid the stall.
PostPosted: Sat Nov 24, 2007 12:21 pm
so does it rev OK in neutral ?
distributor hasn't come loose and turned itself around has it ?
PostPosted: Sat Nov 24, 2007 12:25 pm
yep revs just fine in neutral - only stalls on load
PostPosted: Sat Nov 24, 2007 12:36 pm
haven't got another coil to try have you?
i have NFI when it comes to the box in an a-series but it might be something wrong with 1st gear so have you tried it in reverse or 2nd if it has the grunt,
PostPosted: Sat Nov 24, 2007 12:38 pm
This space for rent
Simon++... I reckon you might be onto something there ;)
PostPosted: Sat Nov 24, 2007 12:41 pm
yep - tried that - the same :cry:
PostPosted: Sat Nov 24, 2007 12:44 pm
Are you running a vacuum advance distributer , is the vacuum line hooked up and has the advance mechanism inside the dizzy fallen apart and over advancing under load ?
PostPosted: Sat Nov 24, 2007 12:54 pm
I will check that - is the advance mechanical as well as vacuum - ie does it have a weights mechanism as well as the vacuum ?
