I now know why door handles droop https://www.ausmini.com/forums/viewtopic.php?f=2&t=38314 |
Author: | Wombat [ Fri Nov 30, 2007 5:48 pm ] |
Post subject: | I now know why door handles droop |
Everyone says you need new 'clock' springs when your door handles droop. Not if it's a MK1 (with English door locks?) ![]() The slider and the cam are both worn which results in the handle spindle rotating too far and the handle itself goes beyond horizontal. ![]() Well I've stuffed them now I may as well try a dob of weld and see if they can be rescued ![]() |
Author: | 1071 [ Fri Nov 30, 2007 7:40 pm ] |
But the clock springs work so well and are so easy to install..... but, I'll admit, a bit pricey. Cheers, Ian |
Author: | d0c [ Sat Dec 01, 2007 12:25 pm ] |
Wombat, how hard is it to take that cover off the mechanism? And how did you do it? Did it include an angle grinder..? |
Author: | Wombat [ Sat Dec 01, 2007 12:37 pm ] |
d0c wrote: Wombat, how hard is it to take that cover off the mechanism?
And how did you do it? Did it include an angle grinder..? Easy to get off - drill out the rivet flange at the back but there in lies the problem - it's not a rivet but a 'post' that is about 3/8" in diameter with a 5/32" hole through the middle - counter sunk with a lip at the top end and an narrow 'extension' at the other that passes though about 1/4" hole in the backing plate and is preened over to secure. By drilling off the preened bit the whole thing is ruined and new ones needed. New locks are $45-$46 from Karcraft or $25-$35 from MiniSpares and others OS - I think I'll get new ones ![]() |
Author: | d0c [ Sat Dec 01, 2007 6:53 pm ] |
hmmmm, thanks. Might need to rethink what I'm trying... Basically I want a passenger side door mechanism (with lock) on the drivers side, I was going to pull one apart like you've done, switch it over, then try and get it all back together. |
