It is currently Wed Aug 13, 2025 8:08 pm
 Post subject: painting and engine
PostPosted: Sat Dec 01, 2007 7:16 pm
Online
i know this may soundlike a stupid question but when you are painting your engine do youpaint your distributor with it or put your distributor in after it is sprayed????? thanks fellas
PostPosted: Sat Dec 01, 2007 7:34 pm
fit it after you've painted the engine Carter. If you leave it in
and mask it up you don't get a good coverage behind it
Tony
PostPosted: Sat Dec 01, 2007 9:34 pm
Give Ash some flowers Nick .
Depends how you feel. I just painted around mine with a brush and I think it turned out pretty good (pulled off some stuff from around it though).
I think mine came up all right. If you have your car off the road (waiting to get registered) or are pulling it out anyway or have the engine out, I would pull it out and paint it separatly.
My 0.02c
PostPosted: Sun Dec 02, 2007 11:23 am
Online
ok fellas thanks anythin else ishouldnt paint green on my block g-box etc????
PostPosted: Sun Dec 02, 2007 9:31 pm
Painted this red-but I think it looks better without paint on the dizzy,oil filter housing,alternator,thermostat housing.and don't paint the g/box.
PostPosted: Mon Dec 03, 2007 8:45 am
Online
why dont paint the g/box?
PostPosted: Mon Dec 03, 2007 8:46 am
High heel ninja
If your going to do it do it properly, take off the carby & manifold,fuelpump,dizzy,starter,radiator etc etc, give it a good wash down with degresser & a high pressure cleaner, get the grease & muck out of everywhere.
Give the engine 2 good coats of paint including the gearbox.
Paint the radiator,starter motor black etc etc
A little bit more effort goes a long way.
Doogie
PostPosted: Mon Dec 03, 2007 8:48 am
Online
ok thanks a lot mate is 400 ml spray can enough to spray an engine?
PostPosted: Mon Dec 03, 2007 8:50 am
High heel ninja
Should be enough, if not get some more, whack it on.
What colour are you painting it?
Doogie
PostPosted: Mon Dec 03, 2007 8:51 am
Online
i ordered the green from mini bits for 27 bux hope its enough
PostPosted: Mon Dec 03, 2007 8:56 am
High heel ninja
I use White Knight Alpine green hammertone, it's in a spray can & it's almost identicle to the factory Cooper S green, available from Bunnings & Mitre 10 nice & easy to use, goes on & sticks well.
Doogie
PostPosted: Mon Dec 03, 2007 8:58 am
Online
ok kool.....thanks for your advice ill let ya know how it goes when its finished....just got a few things to do b4 i spray it.
PostPosted: Mon Dec 03, 2007 9:32 am
Painted the engine in mine the other day.
Actually painted it with brush rather than spray can.
Removed alternator, starter motor, dizzy, leads, plugs, rocker cover.
If you own a clubman, remove the front grille section. Makes life so much easier.
I've done a red block, sliver gear box and head and a gloss black rocker cover.
Touched up radiator with some gloss black too. Looks a million dollars.
Only down side to doing it in the car is you cant paint the back of the engine.
Have some fun, take ya time, its worth the effort for sure.
Jack of all trades, master of none......
PostPosted: Mon Dec 03, 2007 9:43 am
Carter
As all above have said
However, has your engine been chemically dipped - ie is it bare metal ????
If it has, it may need a light spray with a can of etch primer to make the paint stick to the metal.
Mike
PostPosted: Mon Dec 03, 2007 10:43 am
Online
g'day the engine is out not in the car......it is also painted but is showing signs of age.....it has new rings bearing cam and will have a reconditioned head. so i shall just do a good degreaser and clean up and then spray....what ya say about that
Users browsing this forum: No registered users and 209 guests
