Coolant https://www.ausmini.com/forums/viewtopic.php?f=2&t=38354 |
Author: | Harley [ Sun Dec 02, 2007 1:46 pm ] |
Post subject: | Coolant |
This may seem stipid to some but what should I fill my cooling system up with? Straight coolant, straight water or a certain ratio of each? ![]() |
Author: | poeee [ Sun Dec 02, 2007 1:47 pm ] |
Coolant will come either pre-mixed or not. Depends what ya buy to whether you mix it up. |
Author: | Morris 1100 [ Sun Dec 02, 2007 1:52 pm ] |
It all depends on the coolant. The cheap stuff you use straight (because you are paying for 2/3rd's water. The good stuff you use a mix of about 2/3rd water to 1/3rd coolant depending on the brand of coolant. (it could be half and half, it could be 10 to 1, etc.) You don't want to run straight water. It will turn brown and sludgy and soon block the radiator. |
Author: | Gadgets mini [ Sun Dec 02, 2007 3:02 pm ] |
Morris 1100 wrote: You don't want to run straight water. It will turn brown and sludgy and soon block the radiator.
what about water from anywhere other than Goulburn ![]() |
Author: | Blokeinamoke [ Sun Dec 02, 2007 3:56 pm ] |
I always run distilled water and the castol corrsion inhibutor additive. I never run glycol type coolants as they are conductive. |
Author: | Mike_Byron [ Sun Dec 02, 2007 4:24 pm ] |
Blokeinamoke wrote: I always run distilled water and the castol corrsion inhibutor additive. I never run glycol type coolants as they are conductive.
I wondered about that - my engine has a harmonic balance and carries a good tune. (sic!) |
Author: | Blokeinamoke [ Sun Dec 02, 2007 4:28 pm ] |
Mike_Byron wrote: Blokeinamoke wrote: I always run distilled water and the castol corrsion inhibutor additive. I never run glycol type coolants as they are conductive. I wondered about that - my engine has a harmonic balance and carries a good tune. (sic!) maybe if you hum a few bars ![]() |
Author: | 9YaTaH [ Sun Dec 02, 2007 5:33 pm ] |
Post subject: | BARS |
Blokeinamoke wrote: maybe if you hum a few bars
![]() Avoiding a few BARS leaks if you can...terrible stuff that gums up the works ![]() |
Author: | Mick [ Sun Dec 02, 2007 6:16 pm ] |
So is water if you throw enough crusty block jibbers in it. Only a problem if you have stray currents from say a thermo fan however or you mix your inhibitors by brand. http://www.are.com.au/feat/techtalk/straycurrent.htm a good site all round actually... |
Author: | gerg [ Sun Dec 02, 2007 6:34 pm ] |
Have to agree with the Bloke on this one, glycol actually makes water less efficient at transfering heat as well. |
Author: | drmini in aust [ Sun Dec 02, 2007 7:32 pm ] |
I run Nulon glycol in the 1360, mixed 1:3 ratio with Sydney tap water, it cools fine, doesn't rust and lasts me for years. ![]() If it ain't broke....... ![]() |
Author: | simon k [ Sun Dec 02, 2007 8:30 pm ] |
I must be doing something wrong.... I just use straight tap water... doesn't go brown, and never gets hot |
Author: | LS1380 [ Sun Dec 02, 2007 8:34 pm ] |
I can only highly recommend Red Line Waterwetter&Inhibitor-used with distilled water. |
