It is currently Sat Aug 16, 2025 10:49 pm
 Post subject: starting problems...
PostPosted: Sun Dec 02, 2007 3:26 pm
hey guys and gals..
came across a bit of an issue with the car.
when i go to start the car all it does is make a "click" noise...
so i figured it was my starter motor as it was on its way anyway,.
relaced it with a known working one,... and still nothing,...
so i tried to bypass the starter solanoid to see if its the isssue,,,
and now i have lost all electrics? ?
any more ideas? ?
replace the solanoid? ?
thanks in advance..
Tait
EDIT//// i am able to clutch start the car...
PostPosted: Sun Dec 02, 2007 3:28 pm
sounds like solenoid is buggered, or your battery is flat.
i reckon first try charging the battery and cleaning the terminals on the solenoid
battery??
PostPosted: Sun Dec 02, 2007 3:29 pm
you could have a dead short somehwere or your earth strap aint doing de earthing properlike or your battery posts need a clean or battery is flat
- make sure the battery terminals arnt shorting againt the body
PostPosted: Sun Dec 02, 2007 3:30 pm
That sometimes happens to me. I just put it in gear and give it a little nudge... fixes it and I have no idea why! :lol:
PostPosted: Sun Dec 02, 2007 3:45 pm
If you got a "click" but no start the solenoid should be ok.
If you got no electrics after trying to bypass the solenoid make sure you havent bumped a wire loose off the solenoid.
While you're playing with it its probably worthwhile cleaning up the connectors on the solenoid to ensure good contacts.
having said that, I'd say the battery is the original issue. :lol:
PostPosted: Sun Dec 02, 2007 3:46 pm
I is a mookenik
hmmmm. clicking noise then no power hmmmm sounds like a dead battery
PostPosted: Sun Dec 02, 2007 4:18 pm
click happens to me sometimes... Pull the wires of the main power connector thing (where battery strap connects and the starter motor wire goes etc - thing on driver side of motor above clutch housing) pull the wires off this and clean the conections up, probably a bad connection.
Edit: i think when above happened nothing worked so id agree with others said a dead battery - if constant clicking
Brenton
PostPosted: Sun Dec 02, 2007 4:28 pm
Yep - battery
Put it all back together Tait, then either charge the battery and start it or jump start it.
If with a charged battery you still get a click then clean the battery terminals.
Mike
PostPosted: Sun Dec 02, 2007 4:45 pm
If it is a constant ticking while trying to turn it over, I concur with the others regarding dead battery...
PostPosted: Sun Dec 02, 2007 5:26 pm
even though you replaced the starter get a shifter onto the end and turn the shaft.
my delux did this to me, new starter and still tick tick tick, then mattvan had a brainwave and bam, fixed proper
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Sun Dec 02, 2007 5:52 pm
check your fuses in regards to the no electrics.....if you jump the car and it fires up got a feeling its the battery.....time for a new one!!
PostPosted: Sun Dec 02, 2007 8:17 pm
I is a mookenik
basic diagonsis. when u hear click on start up is either dead battery, earthing out somewhere, or ur start solonieds are playing up.
9 times out of 10 its a battery.
if not then check the positive wire to the starter make sure its not shorting out anywhere.
if not and the starter still clicks its starter.
i had sorta same problem but what is was is that when i put my grill back on when i put one of the screws in i screwed straight through the starter positive wire. so it was earthing out.
juz double check that before pulling ur car apart
Users browsing this forum: No registered users and 385 guests
