reverse light https://www.ausmini.com/forums/viewtopic.php?f=2&t=38423 |
Page 1 of 3 |
Author: | henry the mini [ Tue Dec 04, 2007 3:41 pm ] |
Post subject: | reverse light |
Does a 72 Clubby suppose to have reverse light??? |
Author: | feralsprint [ Tue Dec 04, 2007 3:45 pm ] |
Yes a 72 should have reversing lights, it is one of the ADRs introduced in 72 Jon |
Author: | TK [ Tue Dec 04, 2007 3:47 pm ] |
the reversing lights are the rear blinkers. when put in reverse both blikers light up, not flashing of course. |
Author: | simon k [ Tue Dec 04, 2007 4:03 pm ] |
feralsprint wrote: Yes a 72 should have reversing lights, it is one of the ADRs introduced in 72
Jon so it depends what month in '72 the car had it's plate attached, and what month the ADR was introduced ![]() |
Author: | henry the mini [ Tue Dec 04, 2007 5:10 pm ] |
simon k wrote: feralsprint wrote: Yes a 72 should have reversing lights, it is one of the ADRs introduced in 72 Jon so it depends what month in '72 the car had it's plate attached, and what month the ADR was introduced ![]() So what does the mean??? If my car was built before this i dont have the system??? |
Author: | Rodney [ Tue Dec 04, 2007 5:15 pm ] |
Ok....done some work on this car and it's a remote gear change. I don't recall seeing a switch on the casting where you would attach the wires for the reversing lights, so perhaps this car was manufactured prior to the ADR's that stipulated that the rear indicators came on when reverse gear was selected. Does any-one know the month in '72 when the ADR's were put in place. Louis, have a look at the compliance plate - under the bonnet somewhere - and it will show the month as well as the year of manufacture. If it's before the ADR's were changed in 1972, you will be in the clear. Anybody, please feel free to correct me. |
Author: | henry the mini [ Tue Dec 04, 2007 5:38 pm ] |
Here we go 10/72 Cheers |
Author: | Mick [ Tue Dec 04, 2007 5:45 pm ] |
Is it a remote or a rod change? Remotes have the spot for one on the front of the gearbox casing, rod changers have a switch fitted to the change mechanism. |
Author: | feralsprint [ Tue Dec 04, 2007 5:52 pm ] |
the car being a 10/72 will need reversing ligjhts as the ADRs came into force Feb 72 along with the headrests on the seats, the car should also be fitted with twin filament bulb holders in the rear blinkers Jon |
Author: | henry the mini [ Tue Dec 04, 2007 6:51 pm ] |
Mick wrote: Is it a remote or a rod change?
Remotes have the spot for one on the front of the gearbox casing, rod changers have a switch fitted to the change mechanism. You are a legend, fixed!!! Thanks |
Author: | 64cooper [ Tue Dec 04, 2007 7:21 pm ] |
Jon are you sure about the reverse lights being 1972 as my 73 S does not have them ![]() ![]() ![]() |
Author: | feralsprint [ Tue Dec 04, 2007 7:54 pm ] |
64cooper wrote: Jon
are you sure about the reverse lights being 1972 as my 73 S does not have them ![]() ![]() ![]() There are very few original cars out there that have the original gearbox fitted let alone not been hit up the back ![]() Jon |
Author: | Morris 1100 [ Tue Dec 04, 2007 8:04 pm ] |
I have a copy of ADRs that says that ADR1 (Reversing Signal Lamps) was introduced on 1/1/72. Every Mini gearbox is capable of being fitted with reversing lights. Even the 3 syncro was fitted with them at one stage. |
Author: | henry the mini [ Tue Dec 04, 2007 8:34 pm ] |
My 10/72 have gor reversing light, and now they are working ![]() |
Author: | Morris 1100 [ Tue Dec 04, 2007 8:37 pm ] |
Page 1 of 3 | All times are UTC + 10 hours |
