Its an early one, '60 or '61 I reckon. Have you tried the glass dating method? It works for cars with British Triplex glass in the windows.
Dating your car by its windows - based on the original compiled by Neil Cairns.
MG's made in the 1950's to the late 1970's can be dated by the 'TRIPLEX CODE' etched into the toughened glass. My 75 GT has Sicursive side glass but a Triplex heated back-light with a code that fits the date of build of the car. This also works for any other make using TRIPLEX glass.
Note that it dates the GLASS so is only an indication of the cars age assuming the glass is original.
If you are not quite sure of the year of your car but the decade is known just look for two dots in the TRIPLEX logo on the glass.
One dot above T R E or X gives the quarter of the year the glass was manufactured:
T = Jan Feb March
R = April May June
E = July Aug Sept
X = Oct Nov Dec.
but which year?
Nine letters make the word TOUGHENED one dot below a letter gives the year of the decade:
T = 1
O = 2
U = 3 and so on.
However if you see no dot the year is zero.
Say your car is a 1950's MG then
TRiplEX TOUGHENED with one dot over the 'R' in Triplex and the other under the last 'E' in Toughened indicates 'April/May/June 1958'.
In regard to the Minister for Finance, don't forget to tell her that a heritage certificate will increase the final value of the car.
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
