Lining up engine mounts?????
https://www.ausmini.com/forums/viewtopic.php?f=2&t=38532
Author:  ryan [ Fri Dec 07, 2007 10:12 pm ]
Post subject:  Lining up engine mounts?????
Hi everyone
Just putting the motor back in my car, and put new engine mounts on it, but now cant get them to line up with the holes.
Any advise? Tricks?
Ryan
Author:  the bean [ Fri Dec 07, 2007 10:20 pm ]
never give up
Author:  mad-mk1 [ Fri Dec 07, 2007 11:14 pm ]
i bolted loosely 1 side up, and teh otehr side pretty well feel straight in, with the help of a screwdriver
Author:  Harley [ Fri Dec 07, 2007 11:23 pm ]
Get a heavy mate or two and, as mad said, a pointy screwdriver.
When the holes line up just enough for the screwdriver, put in in and lever the rubber
around. :D
Author:  -=MiniMafia=- [ Fri Dec 07, 2007 11:35 pm ]
its a bitch. just keep trying mate :D
Author:  gafmo [ Sat Dec 08, 2007 5:22 am ]
Can be a sod but are you useing engine mounts tghat have th nuts already welded on. We have found these to be thicker than the orginals.
Passistance Screw driver a weighty freind to stand on the engine and a few words
Author:  drmini in aust [ Sat Dec 08, 2007 5:22 am ]
The aftermarket mounts with the captive nuts are too bloody thick. :evil:
I use Rover/originals where possible.
Author:  Anto [ Sat Dec 08, 2007 7:09 am ]
I have found that the mounts without captive nuts were too thick, making it more difficult than it should be. I used one with captive nuts, which was slightly thinner and it lined up easy.
Author:  Drekkus [ Sat Dec 08, 2007 9:00 am ]
Thats what I found and no amount of jumping on the engine or fiddling with screwdrivers could get both back in.I had to go back to the non captive ones.
Author:  mickmini [ Sat Dec 08, 2007 12:59 pm ]
the new ones i got were too thick as well. just learn some new swear words and be persistent.
Author:  MINImal effort [ Sat Dec 08, 2007 6:32 pm ]
Been there as well....
If you compare thicknes of old mounts with new....
The ones I had were visibly thicker.....
...went to Authentic Rover ones and fitted without any hassles...
Good luck...
Author:  ryan [ Sat Dec 08, 2007 11:42 pm ]
all done! Took a while, but i got we got there. They were the ones without captive nuts.
Thanks guys.
