flywheel crank end removal https://www.ausmini.com/forums/viewtopic.php?f=2&t=38545 |
Author: | Kennomini [ Sat Dec 08, 2007 1:24 pm ] |
Post subject: | flywheel crank end removal |
How do I remove this gear? ![]() |
Author: | Mick [ Sat Dec 08, 2007 1:28 pm ] |
Take the primary gear cover (in the picture) cover off and slide the gear off the crank. Also I believe you can pull the primary gear through the primary gear cover by removing the seal around it and then pulling it through. |
Author: | Kennomini [ Sat Dec 08, 2007 1:31 pm ] |
If I pull the flywheel housing off won't oil go everywhere? |
Author: | Mick [ Sat Dec 08, 2007 1:42 pm ] |
Yeah, a lot of oil. You will need to drain the sump. You will also need a replacement gasket and seal. What are you trying to do anyway? |
Author: | Kennomini [ Sat Dec 08, 2007 2:11 pm ] |
I'm just wanting to remove that gear so I can gt some measurements for this project http://www.ausmini.com/forums/viewtopic.php?t=38546 |
Author: | Hanra [ Sat Dec 08, 2007 3:05 pm ] |
Geez.... Good luck with that one mate... Angle grinding gearboxes.....eeeek.. |
