It is currently Thu Aug 21, 2025 2:29 pm
Post new topic Reply to topic  [ 37 posts ]  Go to page 1, 2, 3  Next
PostPosted: Mon Dec 10, 2007 7:45 am
Hi Guys,
Just about to get some new tyres and a wheel alignment done on my K. What do you think are the best tyres available in 10'?
Also, I have adjustable caster rods, rose-jointed bottom arms, tracking and camber rear brackets and the whole car has Hi-Lo's. What height, camber, toe-in(out), caster should I be running to get the best handling car I can???
Thomas
68matic: "i havent seen much head in my life "
PostPosted: Mon Dec 10, 2007 8:12 am
This space for rent
Have a look here:
http://www.ausmini.com/tyres
PostPosted: Mon Dec 10, 2007 8:13 am
I really suggest you take your car to John Leffler at St George Steering at Belmore. Number is in the telephone book or online with whitepages.com.au.
Leffo is one of Australia's mini racing legends and a suspension expert. He wont charge you a fortune and the job will be properly done.
The reason I suggest that is because there is a myriad of possible combinations that are affected by ride height, etc etc etc. You really want someone who knows what they are doing to set up the angles correctly.
Its the difference between a good handling car theat is easy to drive and a pig of a thing.
Mike
PostPosted: Mon Dec 10, 2007 8:57 am
Yep & Yep..Take it to St George and get it done correctly the first time
PostPosted: Mon Dec 10, 2007 9:41 am
Hey thomas,
i've been asking the same question, and a lot of people say the dunlop D93J Formula R, for there price and quality.
Sav
PostPosted: Mon Dec 10, 2007 9:59 am
Thanks guys,
Will give him a call today. How much should I expect to pay for the Dunlops???
PostPosted: Mon Dec 10, 2007 10:43 am
are these road legal?
Lillee - 1969 Morris Mini K
PostPosted: Mon Dec 10, 2007 10:53 am
Last time I checked it was not
PostPosted: Mon Dec 10, 2007 11:25 am
nuclear_mini wrote:
Thanks guys,
Have a look in the tyres link above , 1018cc put a lot of work into getting all the info in to help people with their questions .
PostPosted: Mon Dec 10, 2007 11:26 am
As far as I know they are not legal, not because of the rose joint, but because of the adjustability of the bottom arms.
Thats not to say that engineers and the rta will not frown upon the rose joints, but i dont believe there is anything in the rule book strictly against them...
I have rose jointed gear on my skyline and it isn't is a problem
PostPosted: Mon Dec 10, 2007 2:32 pm
Humour me...
For those people out there with adjustable suspension, what are you running and how well does it handle and what is the comfort level like???
PostPosted: Mon Dec 10, 2007 3:02 pm
nuclear_mini wrote:
Humour me...
The humour part: A duck walks into a bar and asks for a drink, the barman asks how will you pay for it? The duck replies "put it on the bill!"
The suspension question: Most people will tell you, modifying suspension to obtain optimum handling will produce a sharp go-kart like ride at the expense of comfort. They are almost mutually exclusive.
I had my suspension set up by John at St George - I don't have my settings handy.
The life reflection part: In my younger days I used to drive around in road registered race cars with 3000lb springs etc (non mini's obviously) that would jar your fillings out on every bump, leave your ears ringing from the exhaust, and required you to dump the clutch at 5000rpm just to take off at the lights.
KB
PostPosted: Mon Dec 10, 2007 3:06 pm
hey Thomas, in regards to the tyres, i think $125, you should have a look at the link provided at the top, it has a lot of information on all the tyres available. i personally would buy the dunlops, but thats because i want to race my mini, its up to you.
Sav
PostPosted: Mon Dec 10, 2007 3:14 pm
I've got Adjustable Bottom arms, tie rods on the front and hilos in the rear.
Wheel are 5 and a bit inch widened 10inch steelies with Bridgestone rubber.
When i went from the stock setup to the wider wheels, driving went from fun to fantastic, adding the adjustable arms mad everything feel so much more precise, the steering was lighter and the grip was brilliant.
even with standard height and old ish rubber cones in the front
as for the settings, it's different from car to car and driver to driver..
I good rule of thumb is as per the workshop manual and then give it a degree of negative camber.
Here's what i had last time (from top, Toe, camber then castor)
for a list of ausminiers settings, check here...
http://www.ausmini.com/forums/viewtopic.php?t=25470
PostPosted: Mon Dec 10, 2007 6:19 pm
Give Ash some flowers Nick .
sgc wrote:
Glad to see that this is getting some use!
nuclear_mini wrote:
Thanks guys,
It's a pity that some people obviously don't take any note of what other people post - obviously you didn't want to go and find the information your self eh? Can't you read? :roll:
Ah well, you can lead a horse to water...........
Users browsing this forum: No registered users and 288 guests
