Just some Mini-Matic Queries https://www.ausmini.com/forums/viewtopic.php?f=2&t=3863 |
Page 1 of 2 |
Author: | 68matic [ Sat Jan 08, 2005 12:03 am ] |
Post subject: | Just some Mini-Matic Queries |
hi matic blew a head gasket probably a good opportunity to see if the cooper head was nicked 1) would a head stamp of "12A 1456 SM" or "12__1_6" be characteristic of a matic head? i was told matics came out with Small Cooper heads and "12G295" would be expected with larger valves by Doogie and Steve, not sure what the one off mine's goin on about. my block has the stud/washer/nut thing so people tell me its an english block 2) did matics come with metal universal joints, or rubber ones with metal U hooks, connecting the diff to the driveshafts? thanks |
Author: | drmini in aust [ Sat Jan 08, 2005 5:48 am ] |
Post subject: | Re: Just some Mini-Matic Queries |
68matic wrote: hi
matic blew a head gasket probably a good opportunity to see if the cooper head was nicked 1) would a head stamp of "12A 1456 SM" or "12__1_6" be characteristic of a matic head? i was told matics came out with Small Cooper heads and "12G295" would be expected with larger valves by Doogie and Steve, not sure what the one off mine's goin on about. my block has the stud/washer/nut thing so people tell me its an english block 2) did matics come with metal universal joints, or rubber ones with metal U hooks, connecting the diff to the driveshafts? thanks Duc, 1. 'Matics (UK 850, and our 998) all had the 12A1456 head, with standard 998 valves. No 295's here.. ![]() They had 9:1 C/R, because the pistons had less dish. Also had HS4 carb before any others. All this added up to 3HP more than stock 998 Deluxe. Wow... ![]() They all had studs, as all autos were English blocks. Like the 1275 auto the oilways are funny- so won't go on a manual box without reworking. 2. All had metal Hardy Spicer U/Js, same as Cooper S. No rubber joints. ![]() I suggest you use a standard composition gasket, not the copper one. We've had some trouble with those lately. Best gasket around for 998/1098 at the moment is the `ACL' one, IMO. Repco or AutoOne have it or can get. ![]() |
Author: | gafmo [ Sat Jan 08, 2005 7:57 am ] |
Duc sorry to here you have blown a head gasket..I know how you feel. Why do you feel its blown 'Yer get the ACL head Gasket set you will notice it straight away it has blue traces through it |
Author: | 68matic [ Sat Jan 08, 2005 9:13 am ] |
a) Kev thanks for that info, can i ask where it came from? its good coz it shows my engine has been not picked and pulled and had parts nicked but "2Ss and a Clubman" (Doogie) and "1969AllOriginalMatic/CalifornianMoker" have sworn that matics came with small cooper block heads with bigger valves, to compensate for the auto box. Doogie said he's even pulled a couple off with a 12G295 casting ![]() Incidently, Californian Moker wanted to sell his matic, but couldnt find the Cooper head casting so was sad about that b) Thanks Jim, we took the head off Herman and it was blown between cyl 3/4 and darkish around 1/2 and 2/3. He'll be off for a while but im not too bothered, he'll have a good rest |
Author: | IwannaMini [ Sat Jan 08, 2005 9:24 am ] |
Author: | 68matic [ Sat Jan 08, 2005 9:29 am ] |
well, initially we thought it may have been a valve burn out coz i was pushing it on the cruise but a head gasket going may have been from the same reason, or maybe the head was put on in the wrong way (involves 3 stages with correct torque etc) and that wouldve been inevitable. either way, absolutely no regrets met lovely people, had a great day, glad he didnt kick the bucket and say "f*cket" on the actual run |
Author: | drmini in aust [ Sat Jan 08, 2005 9:39 am ] |
68matic wrote: a) Kev thanks for that info, can i ask where it came from?
its good coz it shows my engine has been not picked and pulled and had parts nicked but "2Ss and a Clubman" (Doogie) and "1969AllOriginalMatic/CalifornianMoker" have sworn that matics came with small cooper block heads with bigger valves, to compensate for the auto box. Doogie said he's even pulled a couple off with a 12G295 casting ![]() Incidently, Californian Moker wanted to sell his matic, but couldnt find the Cooper head casting so was sad about that b) Thanks Jim, we took the head off Herman and it was blown between cyl 3/4 and darkish around 1/2 and 2/3. He'll be off for a while but im not too bothered, he'll have a good rest Info from 2 `matics I have owned or worked on, also the Leyland `Black Book'.. If they had a 295 head someone has fitted it! I put a 202 on mine when the old one cracked.. You would lose torque down low with a 295, be NBG with a converter. 295 was only fitted to twin carb cars.. 998 Cooper, Sprite 1098, and MG1100. |
Author: | 68matic [ Sat Jan 08, 2005 10:24 am ] |
interesting... but thats good, Herman is still a riggy matic thanks doc btw whats "NBG"? |
Author: | drmini in aust [ Sat Jan 08, 2005 11:38 am ] |
NBG= No Bloody Good, as distinct from No F'ing Good.. ![]() |
Author: | 9YaTaH [ Sat Jan 08, 2005 11:58 am ] |
Post subject: | Technical Terminolgy |
drmini in aust wrote: NBG= No Bloody Good, as distinct from No F'ing Good..
![]() Good to see you maintaining the use of the correct terminolgy Doc, can you quote the ISO or Australian Standard for those two! ![]() |
Author: | drmini in aust [ Sat Jan 08, 2005 12:17 pm ] |
Errr.... NO, but I can claim prior use for the last 50+ years! ![]() |
Author: | bnicho [ Sat Jan 08, 2005 4:17 pm ] |
The Morris 1100 Auto had the 12G295 head, not the Mini Matic. ![]() |
Author: | drmini in aust [ Sat Jan 08, 2005 5:14 pm ] |
1098 auto were pretty rare here weren't they, Brett - most `Morris 1100' autos sold were 1100S?? ![]() |
Author: | amrmeaner [ Sat Jan 08, 2005 7:10 pm ] |
![]() I have a1969 998 minimatic. When I bought the mini it had a very bad oil leak from the main end seal behind the convertor. Since then I have had the convertor recon and are currently repalcing the covertor bush. I am keen to talk tot and meet people with minimatics. I am having a lot of trouble getting parts and recently had to imprt a seal from the USA. Any help or advice would be much appreciated Regards Mr Meaner |
Author: | drmini in aust [ Sat Jan 08, 2005 7:26 pm ] |
I have had a few autos- Morris 1100S/1300 and 998 MiniMatics. I stripped and fixed the 998 when it had no forward drive. Karcraft told me a while back all parts are available in UK, and he can get whatever I want. Alternatively try this site- they have ALL the bits and will ship to you. http://www.jpat.co.uk/ No I've not used them but Todd Miller on MM site uses them all the time. Check his site too for info on the AP automatics. http://www.austinamericausa.com/ Same box basically was used in 998 MiniMatic and 1275 Austin America. ![]() |
