Difference between wet and dry front subframes??
https://www.ausmini.com/forums/viewtopic.php?f=2&t=38660
Author:  Typhoon [ Wed Dec 12, 2007 8:22 am ]
Post subject:  Difference between wet and dry front subframes??
Hey all,
I tried a search but it wasn't all that helpful. Which what a noob like me should do first :D
Just want to know if there are any differences between the towers size/dimesions from a hydro to a dry front subframe. have got a hydro front now and am going to give it the chop to put a 4efte in the front. wondering if the towers on a dry frame were physically smaller as it would be a better base to work from in that case.
thanks in advance
Ty
ps have been a reader of ausmini for the past 3 years, it has taken me awhile for my first post hey!!!!!
Author:  Harley [ Wed Dec 12, 2007 11:15 am ]
The difference is inside the towers, there are little tags that hold the hydro bags up.
If removed, the subframe will be for dry/cone suspension.
:D
Author:  sgc [ Wed Dec 12, 2007 12:53 pm ]
Isn't there a slight difference in tower height too? One of them is slightly taller than the other IIRC, or there's a spacer there or something.. :?:
Author:  Mick [ Wed Dec 12, 2007 1:08 pm ]
The hydro subframes have a spacer that sits between the subframe and the body, about 6mm (1/4 inch) thick from memory....
I believe as well that the shape where the hydro bag sits differs from the dry subframe. Plenty of people still manage to stuff the rubber cones in anyway.
Top arm on the front suspension differs to suit the hydro bag (knuckle sits further out on wet) so will give a stiffer ride on dry.
One subframe uses bolts in the towers, the other uses studs, but no difference in fitting it up.
