i guess it all depends on the end result you want.
by now your paint is more than likely in need of some aid, whether it be a complete colour sand followed by a polish/wax or simply just a clay bar and polish/wax.
if your shine is still there and you dont have any scratches i would suggest a simple detail would suffice. that would include, a wash to get rid of surface dirt, followed by a clay bar to remove all previous polishes and waxes, then followed by a good quality polish, followed by a good quality wax (ive left out names as every1 has there favourites - it completely subjective - but there are quality brands that can be found very easily at your local auto store)
if your after a completely orange-peel-free flawless showroom finish, then you will need to colour sand. that involves cutting your finish back with varying grades of wet&dry sandpaper (usually starting at 1500 working through 2000 and 2500 - some go as far as 3000 and beyond - using heaps of water and a bit of detergent to stop clogging) to get rid of the orange peel and get a super flat surface, followed by various grades of cutting compund on a buffer to get rid of the swirl marks. once thats done you can polish and wax to keep the flawless finish in tact. (NOTE: i havent gone into any detail about products, pads, techniques, etc etc as i am no expert but if you dont know exactly what to do then you need to do some more reading on the subject.)
heres an excellent example of a home done restoration with tips and techniques all the way through.
http://www.autobody101.com/forums/about5183.html
end ramble, but the point is, do more research and decide on the final outcome you want.
