It is currently Wed Aug 06, 2025 1:30 am
 Post subject: Cooper S fan spacer?
PostPosted: Thu Dec 13, 2007 9:24 pm
Did Cooper S's come with a fan spacer standard or was the plastic fan just bolted up to the pulley. Engine has the large 2 piece S crank damper and when the fan is bolted up to the pulley, is very close to the crank damper :shock: If they did come with a spacer, how thick was it?
Steve
PostPosted: Thu Dec 13, 2007 10:27 pm
yep, should have a spacer, about 1/4" thick - I put 2 of them on my dad's car
make sure you put the fan on the right way too - it's marked on it ;)
PostPosted: Thu Dec 13, 2007 11:20 pm
i assume this improves the cooling?
by moving the fan closer to the rad?
PostPosted: Fri Dec 14, 2007 12:40 am
simon k wrote:
yep, should have a spacer, about 1/4" thick.make sure you put the fan on the right way too - it's marked on it ;)
Simon k not all plastic fans have the markings you are talking about   :shock:  ( i have found, especially the new ones).....best way to tell is by the metal inserts in the fans mounting holes....1 side has a large surface area (like a washer and it also sticks out about 2-3mm from the plastic) which is where the mounting bolt heads and split washers should mount too, the other side has a smaller face on the insert and is flush with the plastic of the fan this side goes to the spacer/pulley. :D
PostPosted: Fri Dec 14, 2007 9:08 am
I'm running a bit hot lately (ok it is 34 degrees today) but I was wondering if this fan is set up correctly ...
... from the point of view of the engine the fan is spinning anti clockwise.
-- Simon // VMCI Member 2674 --
PostPosted: Fri Dec 14, 2007 9:13 am
That should be right. It should blow through the radiator.
PostPosted: Fri Dec 14, 2007 9:15 am
Erm correct me if I'm wrong but I thought Cooper S's came with the 16 blade metal fans and not the plastic ones?
PostPosted: Fri Dec 14, 2007 9:17 am
Thanks.
PostPosted: Fri Dec 14, 2007 10:32 am
Mk1 steel 16 bladed, Mk2 yellow plastic.
AFAIK :D
Sir Alec! we are not worthy!
