Cooper S fan spacer? https://www.ausmini.com/forums/viewtopic.php?f=2&t=38716 |
Author: | justminis [ Thu Dec 13, 2007 9:24 pm ] |
Post subject: | Cooper S fan spacer? |
Did Cooper S's come with a fan spacer standard or was the plastic fan just bolted up to the pulley. Engine has the large 2 piece S crank damper and when the fan is bolted up to the pulley, is very close to the crank damper ![]() |
Author: | simon k [ Thu Dec 13, 2007 10:27 pm ] |
yep, should have a spacer, about 1/4" thick - I put 2 of them on my dad's car make sure you put the fan on the right way too - it's marked on it ![]() |
Author: | cush [ Thu Dec 13, 2007 11:20 pm ] |
i assume this improves the cooling? by moving the fan closer to the rad? |
Author: | BALLISTIC [ Fri Dec 14, 2007 12:40 am ] |
simon k wrote: yep, should have a spacer, about 1/4" thick.make sure you put the fan on the right way too - it's marked on it Simon k not all plastic fans have the markings you are talking about ![]() ![]() ![]() |
Author: | whiteski [ Fri Dec 14, 2007 9:08 am ] |
I'm running a bit hot lately (ok it is 34 degrees today) but I was wondering if this fan is set up correctly ... ![]() ... from the point of view of the engine the fan is spinning anti clockwise. |
Author: | poeee [ Fri Dec 14, 2007 9:13 am ] |
That should be right. It should blow through the radiator. |
Author: | Lillee [ Fri Dec 14, 2007 9:15 am ] |
Erm correct me if I'm wrong but I thought Cooper S's came with the 16 blade metal fans and not the plastic ones? |
Author: | whiteski [ Fri Dec 14, 2007 9:17 am ] |
Thanks. |
Author: | graham in aus [ Fri Dec 14, 2007 10:32 am ] |
Mk1 steel 16 bladed, Mk2 yellow plastic. AFAIK ![]() |
