It is currently Sun Jul 27, 2025 2:51 am
Post new topic Reply to topic  [ 44 posts ]  Go to page 1, 2, 3  Next
Do you think your mini is reliable?
Yes, I drive it every day with little/no problems 46%  46%  [ 42 ]
Yes, It's a weekend warrior; very few problems 25%  25%  [ 23 ]
Yes, I look at it in my shed and never drive it; so it never breaks down 2%  2%  [ 2 ]
No, I WOULD drive it everyday if I could 7%  7%  [ 6 ]
No, Breaks down regularly 4%  4%  [ 4 ]
My mini isn't on the road so I can't tell 16%  16%  [ 15 ]
Total votes : 92
PostPosted: Fri Dec 14, 2007 9:51 pm
Give Ash some flowers Nick .
Just thought it would be a good gauge to have to see how many members think that their car (mini - overall opinion if you own more than one) is reliable or not.
PostPosted: Fri Dec 14, 2007 9:57 pm
if you have a mini that has no problems THERE IS A PROBLEM
PostPosted: Fri Dec 14, 2007 10:03 pm
So my car has problems then? I've only been stranded on the side of the road 2 times in the past 5 years in my car (using it as a daily). One time I thought it was the fuel pump (turned out to be crud in the tank) and the other was the accel cable snapped - fixed that one though.
It doesn't feel like it has problems to me; my car must be just that much better than a normal mini :lol:
PostPosted: Fri Dec 14, 2007 10:31 pm
same here, mines NEVER broken down, once i couldnt get the fuel cap off, but i put it on wrong way in the first place
PostPosted: Sat Dec 15, 2007 12:07 am
Now I've got the 1990 Rover lump in it I have no problems at all :D
PostPosted: Sat Dec 15, 2007 5:05 am
Will let you know after I drive it off the boat in Melbourne and head to Adelaide via Mt Gambier in early Jan. That should test it's reliability. 8)
But so far it's been great since the rebuild.
Peter.
1982 Honda CB1100RC (ours)
PostPosted: Sat Dec 15, 2007 5:37 am
my '92 SPi is my every day car and i don't pamper it. maybe that makes strong enough not to have problems :wink:
Rover 214 atm ....
PostPosted: Sat Dec 15, 2007 5:47 am
Mines has actually failed on me once. The 12v supply to the ign coil was intermittently making contact inside a spade crimp connector where its plugged onto the pos on the coil. Every time i accelerated the motor would rock ever so slightly, causing the connection to go open circut. Was a quick fix though.
PostPosted: Sat Dec 15, 2007 6:21 am
Th only problems i've had with mini's (K and an S), that actually affect driving it every day are flat tyres, and that is over a span of 5 years.
My S does currently have busted exhaust, but it's still drivable with the exhaust tied up.
PostPosted: Sat Dec 15, 2007 7:51 am
:lol: my main problem is running out of fuel (sender doesn't work :shock: , hasn't for years and i will get around to replacing the tank with a later sender unit one day :) ) untill about 2 months ago when the rod bolts let go near the hay shed at philip island at very high rpm...(not bad for 10years of very enthusiastic driving)...was a good excuse to make the new motor "more fun"!! :lol: :lol:
PostPosted: Sat Dec 15, 2007 8:01 am
mine used to break down everytime it went to the mechanics, stopped taking it there does not break down now so yes mine is good
PostPosted: Sat Dec 15, 2007 11:30 am
I want to have Al's babies
Of course it's reliable! It's a ROVER! :D
PostPosted: Sat Dec 15, 2007 11:35 am
other than a wheel falling off - :roll: - it has never failed in its limited life
PostPosted: Sat Dec 15, 2007 11:39 am
Rover Cooper
Mine is a freak, everything works fine, starts first time, and there are no oil leakes, runs like a dream, smooth as silk to drive.
PostPosted: Sat Dec 15, 2007 11:45 am
you do realise that we are talking about your mini here :P
