Do you think your car is reliable? https://www.ausmini.com/forums/viewtopic.php?f=2&t=38741 |
Page 1 of 3 |
Author: | 1018cc [ Fri Dec 14, 2007 9:51 pm ] |
Post subject: | Do you think your car is reliable? |
Just thought it would be a good gauge to have to see how many members think that their car (mini - overall opinion if you own more than one) is reliable or not. |
Author: | Bubbacluby [ Fri Dec 14, 2007 9:57 pm ] |
if you have a mini that has no problems THERE IS A PROBLEM |
Author: | 1018cc [ Fri Dec 14, 2007 10:03 pm ] |
Bubbacluby wrote: if you have a mini that has no problems THERE IS A PROBLEM
So my car has problems then? I've only been stranded on the side of the road 2 times in the past 5 years in my car (using it as a daily). One time I thought it was the fuel pump (turned out to be crud in the tank) and the other was the accel cable snapped - fixed that one though. It doesn't feel like it has problems to me; my car must be just that much better than a normal mini ![]() |
Author: | cookie720 [ Fri Dec 14, 2007 10:31 pm ] |
same here, mines NEVER broken down, once i couldnt get the fuel cap off, but i put it on wrong way in the first place |
Author: | Kennomini [ Sat Dec 15, 2007 12:07 am ] |
Now I've got the 1990 Rover lump in it I have no problems at all ![]() |
Author: | peter1 [ Sat Dec 15, 2007 5:05 am ] |
Will let you know after I drive it off the boat in Melbourne and head to Adelaide via Mt Gambier in early Jan. That should test it's reliability. ![]() But so far it's been great since the rebuild. Peter. |
Author: | KLAS [ Sat Dec 15, 2007 5:37 am ] |
my '92 SPi is my every day car and i don't pamper it. maybe that makes strong enough not to have problems ![]() |
Author: | Hanra [ Sat Dec 15, 2007 5:47 am ] |
Mines has actually failed on me once. The 12v supply to the ign coil was intermittently making contact inside a spade crimp connector where its plugged onto the pos on the coil. Every time i accelerated the motor would rock ever so slightly, causing the connection to go open circut. Was a quick fix though. |
Author: | Drewus [ Sat Dec 15, 2007 6:21 am ] |
Th only problems i've had with mini's (K and an S), that actually affect driving it every day are flat tyres, and that is over a span of 5 years. My S does currently have busted exhaust, but it's still drivable with the exhaust tied up. |
Author: | BALLISTIC [ Sat Dec 15, 2007 7:51 am ] |
Author: | lil-ute [ Sat Dec 15, 2007 8:01 am ] |
mine used to break down everytime it went to the mechanics, stopped taking it there does not break down now so yes mine is good |
Author: | boho [ Sat Dec 15, 2007 11:30 am ] |
Of course it's reliable! It's a ROVER! ![]() |
Author: | Blokeinamoke [ Sat Dec 15, 2007 11:35 am ] |
other than a wheel falling off - ![]() |
Author: | Davo111 [ Sat Dec 15, 2007 11:39 am ] |
Mine is a freak, everything works fine, starts first time, and there are no oil leakes, runs like a dream, smooth as silk to drive. |
Author: | Blokeinamoke [ Sat Dec 15, 2007 11:45 am ] |
Davo111 wrote: Mine is a freak, everything works fine, starts first time, and there are no oil leakes, runs like a dream, smooth as silk to drive.
you do realise that we are talking about your mini here ![]() |
Page 1 of 3 | All times are UTC + 10 hours |
