(*&#$(^%@$%!@_ Pinion Nut https://www.ausmini.com/forums/viewtopic.php?f=2&t=38756 |
Author: | Wombat [ Sat Dec 15, 2007 4:03 pm ] |
Post subject: | (*&#$(^%@$%!@_ Pinion Nut |
Anyone in Brisbane got 3 meters of 2" steel pipe cause 1.5 meters of 1" pipe is not enough ![]() |
Author: | 9YaTaH [ Sat Dec 15, 2007 4:14 pm ] |
Post subject: | :idea: |
are you tightening it or loosening it ![]() |
Author: | Blokeinamoke [ Sat Dec 15, 2007 4:17 pm ] |
got a block and tackle. Run the block and tackle from the roof and take the free end and wrap it around the pipe and haul away - will increase the mechanical advantge without increasing the length of the pipe |
Author: | Wombat [ Sat Dec 15, 2007 4:25 pm ] |
No - I need a bigger pipe to fit over a bigger breaker bar - the smaller diameter one I'm using is bending without undoing the nut plus I'm starting to split the end of the pipe |
Author: | Morris 1100 [ Sat Dec 15, 2007 4:35 pm ] |
While you stand on the pipe get someone to hit the pipe near the socket with a hammer. ![]() |
Author: | Wombat [ Sat Dec 15, 2007 7:46 pm ] |
Thanks Morris1100 - that worked a treat - only took one blow with the hammer and it let go ![]() |
Author: | Morris 1100 [ Sat Dec 15, 2007 7:51 pm ] |
Glad to help! It is a trick that should be spread around. I invented that on the side of the road one night with truck wheel nuts and a short bar. The hard bit was hitting the bar while standing on it! ![]() |
Author: | peterw [ Mon Dec 17, 2007 10:29 am ] |
If you have access to a decent rattle gun get that onto it. The impact does wonders with stuck nuts. Pete |
Author: | Wombat [ Mon Dec 17, 2007 11:01 am ] |
peterw wrote: If you have access to a decent rattle gun get that onto it. The impact does wonders with stuck nuts.
Pete Not to mention introducing stress faults into gear teeth that can cause fractures later down the track ![]() |
